(Yet another) E Brake thread. - JeepForum.com
post #1 of 15 Old 03-30-2013, 05:54 AM Thread Starter
ukjeeper
Failed yearly vehicle inspection (MOT) due the POS '91 YJ foot E Brake not holding worth a damn. We all know YJ E Brakes are crap, but unfortunately the government over here needs to see some E Brake action going on!
Been searching for a solution in all the usual places but not finding anything that is different to the "it's the cable adjustment", "It's the drum adjustment" solutions.
Both the rear brakes (new shoes) are dialed in (using the star wheel) just right (hydraulic brake system is working fine on the test rollers), and the (new) cable is set right. But the E brake still isn't working. Even my inspection guy (used to be a Jeep stealership mech) couldn't see why, without taking the drums off.
Until i get this sorted i'm not going to get through inspection, so any other ideas would be appreciated.
ukjeeper is offline
post #2 of 15 Old 03-30-2013, 06:32 AM
jay-h
The thing with brake cables is that as they age, internal friction increases, especially under load (the cable may actually appear to move ok under under light load.) The best thing I have found for cables is a product called Dri Slide, it penetrates like crazy (much more that WD40 etc), pour it in one end and it comes out the other.
It's readily available on the internet, but you might try a gun shop, apparently it's also very good at keeping mechanisms from gumming up in storage (but other gun lubes don't necessarily work for cables).
Also check motorcycle shops.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #3 of 15 Old 03-30-2013, 11:16 AM
SLCSmoker
Ahh the dreaded MOT. You have my sympathies. As an ex-pat I appreciate more than most the US version of the 'inspection'. 4 wheels, check.. horn works.. check. Yep it passes! I lost count of the number of times I took a vehicle to an MOT only for the greasy, flat cap wearing shop guy to say "its yer bushes mate, they need replacing". 300 quid later and bushes looking mysteriously undisturbed I would have the MOT. Nope not missing it at all! I'm about to tear into my rear brakes and e-brake too but it passed the inspection with an 'advisory'.
SLCSmoker is offline
post #4 of 15 Old 03-30-2013, 12:44 PM Thread Starter
ukjeeper
All three cables are moving freely. The main one is new, the other two have been lubed up and slide with minimal resistance.
The equaliser bar is there, as is it's small spring.
The pedal doesn't go all the way down to the floor, as I have it adjusted to just over 1/2 way.
Think I may have figured what it may be. Took the drum off, pressed the parking brake, and noticed that the main brake 'arm' (that goes from the cable to the top of the rear shoe, pivots on the equaliser bar) is hitting the bearing housing, preventing full travel of the shoe(s).
I've taken the arms off, ground down the affected area to give more travel and put them back on.
Haven't had a chance to put it back on the tester yet, but my very unscientific test, standing on the breaker bar while putting the lugnuts back on, seemed encouraging. Jeep didn't move at all.
ukjeeper is offline
post #5 of 15 Old 03-31-2013, 09:35 AM Thread Starter
ukjeeper
To give an idea on what i've done, the arm was hitting the housing (marked in the red circle), so i've removed the area marked with the red arc.
ukjeeper is offline
post #6 of 15 Old 03-31-2013, 09:39 AM
Old4X
1990 CJ7
Some crusty looking parts there.
Has that brake arm been welded? Doesn't look right.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 15 Old 03-31-2013, 09:43 AM
jay-h
Something bothers me about that: when you see an obvious interference like that, you can be sure it's not like that on all the gazillions of Jeeps out there. Something else isn't right whether it's wrong part, missing part, incorrectly assembled part ... but it has to be something.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #8 of 15 Old 03-31-2013, 05:26 PM Thread Starter
ukjeeper
It may (or may not) have something to do with the ARB C-CLIP eliminator kit. As I understand it it converts the D35C into a "full floater". But if the housing is larger (for the outer bearings) it might be what's interfering with the arm, which is all D35 'stock'.
And that's just surface "crud", looks worse as the picture is zoomed in.
ukjeeper is offline
post #9 of 15 Old 03-31-2013, 08:44 PM
flea1987
There was a recall on them I believe, if so just take it to a dealership and make them fix it, I'll try to confirm
flea1987 is offline
post #10 of 15 Old 03-31-2013, 08:45 PM
flea1987
Yup, make them, fix it http://www.automd.com/recall/jeep_m/wrangler_mm/1990_y/
http://www.automobilemag.com/am/1991...r/recalls.html
flea1987 is offline
post #11 of 15 Old 04-01-2013, 03:31 PM Thread Starter
ukjeeper
I'll look into it. However, not sure if I'll get much success. Although I have a US vehicle, the UK spec YJ's had a handbrake instead of a foot brake. Any legal pressure I can throw at them?
ukjeeper is offline
post #12 of 15 Old 04-01-2013, 03:44 PM
Old4X
1990 CJ7
You can contact Chrysler to see if there is an outstanding recall on your vehicle.
Just go to the company website, and you can find recall contact info.
Old4X is offline
post #13 of 15 Old 04-02-2013, 09:05 AM
flea1987
Hope that helped some, only reason I knew about it is because the PO of my jeep told me he already took it in for that recall and had it fixed, He did say they gave him a hard time, but they fixed it
flea1987 is offline
post #14 of 15 Old 04-03-2013, 01:32 AM Thread Starter
ukjeeper
Booked in at local Stealership for the 15th. Don't think they really heard me trying to explain its a US spec parking brake that needs replacing.
Now waiting for them to actually look up the recall notice, before i get the phone call...
ukjeeper is offline
post #15 of 15 Old 04-03-2013, 03:58 PM
HaskiE
HaskiE's Avatar
are you saying there are handbrake parts for a YJ? not to de-rail, but if so, where could I find these gems???
Goodluck with the stealership!!
#theneverendingaxe
HaskiE is offline
