Yet another 89 YJ internal external slave swap question - JeepForum.com
post #1 of 12 Old 08-11-2013, 11:22 PM Thread Starter
iitywybmad
Hi all-
New to the forum, have been lurking for a while. Great place. Spent part of today doing an internal to external swap on the clutch slave. Went pretty well, but have one question. I got the bell and the master and slave out of a 92 wrangler. The master, slave and line is complete and bled, but aside from the difference in mounting to the firewall, I also noticed the rod on the master is about an inch longer than the one on my old master. Do I have a problem here, I can I just bleed it after modding the install? If I do bleed it, I assume the bleeder is at the slave? I didn't take a real close look cause a shower was calling bigtime...
Thanks !
iitywybmad is offline
post #2 of 12 Old 08-12-2013, 06:40 AM
jokerchief462
I made a new rod for my master. Used my old rod end to fit the peddle mount because when you drill the appropriate hole in the plastic all I could see was a fail on the trail. I used the new plunger end into the master. I figured the length and welded the two together.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 12 Old 08-12-2013, 12:01 PM Thread Starter
iitywybmad
Sounds like you had the opposite issue that I did. The rod on the new master I have out of the 92 is longer than the old. I just hate to shorten it and find that I don't have enough pedal to engage. I don't know what the difference in geometry is between the years so I guess I will just put it in as is and see how it behaves. The old one was releasing at that floor and I am afraid this one will be engaged all the time without having to depress the clutch.???
My ride is an 89. the donor was a 92.
post #4 of 12 Old 08-12-2013, 12:41 PM Thread Starter
iitywybmad
I figured a picture tells a thousand.....the top is the old, the bottom is the new. A deceptive angle on the pic, but the new rod is about an inch longer than the old, (maybe that's why she left?),...so what do you all think? Should I try as is and then shorten it if it doesn't work?
Thanks!
post #5 of 12 Old 08-12-2013, 12:47 PM
grandboost98
The only help I can give here is that I didnt change the length of the master cylinder rod on my 89. I did have to make the hole larger, 1/2" to be exact, for it to fit on where it connects to the clutch pedal.
Where did you get your parts from though cause the line coming out of my new master still looks like the one on top in your picture and the rod has a plastic piece at the end instead of all metal like both of yours.
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #6 of 12 Old 08-12-2013, 12:59 PM Thread Starter
iitywybmad
I got the new parts from a local guy here that was building a ride and had the 92 donor. I thought he said it was a 92 wrangler. I was there as he was pulling it. I didn't note the year, it was well into the dismantled stage....
post #7 of 12 Old 08-12-2013, 01:06 PM Thread Starter
iitywybmad
Just pinged the guy that sold the parts...it was out of an 02
post #8 of 12 Old 08-12-2013, 01:07 PM
grandboost98
I thought 92 was still an internal slave? I used parts from a 94/95
EDIT: Yeah Im not too sure on the 02 master. Id assume thatd be different
post #9 of 12 Old 08-12-2013, 01:12 PM
HaskiE
huh. I never knew the master cyl rods were different lengths!??
I have a '92 and it came with an internal slave - it blew up too many times and I swapped it with an XJ external slave & bell housing and spliced the two lines together. It never did hold a seal very good, so I ended up getting the Crown Automotive - Hydraulic Clutch Master Cylinder Assembly part# CRO52104113
http://www.4wd.com/Jeep-Drivetrain-J...pn=CRO52104113
from the sound of it, the external slave is 1994+
#theneverendingaxe
HaskiE is offline
post #10 of 12 Old 08-12-2013, 03:46 PM
Reno72
This is correct, the new bell housing should be from a 95, 92 was still internal. Maybe all the parts he got were from an 02.
Reno72 is offline
post #11 of 12 Old 08-13-2013, 12:15 AM Thread Starter
iitywybmad
Yep, as I noted a few posts back, the parts were out of an 02. Sorry for the confusion. The Master for the 02 will not fit anyway as it is too long and hits the booster. I pulled the external slave off what I have and ordered the braided SS line and adapters from advanced adapters. They machine the adapters in house. I could not find any other adapters, anywhere else to mate the difference or make my own line up. Thanks for the help!
post #12 of 12 Old 08-13-2013, 10:35 AM
flcracker
I swapped an ax 5 from an '02 into my '92 using all the clutch stuff from a 94-95 Wrangler..... bolted right together and is fine (knocks on wood)....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
