yes, another locker ? - JeepForum.com
post #1 of 5 Old 01-22-2002, 01:27 PM Thread Starter
Skeeter
I'm thinking of adding a Detroit Truetrac.
I have a everyday driver and want better traction if possible. I've heard that lockers could actually make it worse in the snow.
I had the stock Tracloc option on a cherekee and i like the way it performed.
Is the truetrac a good idea being thats its a limited slip?
Any input would be great
Skeeter is offline
post #2 of 5 Old 01-22-2002, 04:42 PM Thread Starter
Skeeter
anybody?
Skeeter is offline
post #3 of 5 Old 01-22-2002, 07:02 PM
bob91yj
For driving in slippery conditions the limited slip is a good choice. Of course it's only a limited slip on the trail as well. Decisions, decisions.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #4 of 5 Old 01-22-2002, 09:20 PM
RodeoRob
RodeoRob's Avatar
it all depends on what you want... yes, a limited slip is better for the snow/ice as a locker will tend to push you in a straight line and any touch of the gas in a corner will you a 'spinnin... But that doesn't stop me from getting in my fully locked truck and heading out in every snow we have. It just takes some cautious driving and knowing how your vehicle is going to react.
If you do a lot of driving in snow/ice with very little offroad, LSD is probably a better choice. If you do a lot of offroad or plan to, you might wanna look at a locker... i don't care how good of an LSD you have, a locker is going to take you further off the road.
But as far as LSDs goes, the Truetrac is a good one... far better than your stock unit. It uses gears as opposed to clutch packs which means it won't get worn out as you use it.
Another thing to consider is install costs. The Truetrac is a carrier replacement and will need to be installed by a professional as gear resetting will be required (you're looking at about $200 labor for this). A lunchbox style locker such as the Powertrax No-Slip or Lockright will cost just about as much as the LSD, but can be installed by most weekend mechanics in a few hours.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #5 of 5 Old 01-23-2002, 09:28 AM Thread Starter
Skeeter
thanks for your input!
Skeeter is offline
The Grizzly Locker, The Spartan Locker, and The Zip Locker (Yukon's latest...) Apollo12227 YJ Wrangler Technical Forum 25 04-07-2013 08:35 AM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
LOCKER ISSUE > Just installed lunchbox locker - problems msavard TJ Wrangler Technical Forum 7 12-26-2006 11:11 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
