Quantcast Yeah, I'm headed for a SBC in the YJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yeah, I'm headed for a SBC in the YJ
Old 09-25-2007, 09:49 PM   #1
learfxr
I found a SBC, trans and case for $500. I ordered the Novak engine mounts.
What else am I in for here? I can do the driveshafts, trans mount that kind of stuff. Done it once to make my TF727/NP208 combo work.
What else am I gonna go broke getting? I've never researched this subject cause I figured it would be at least a year before I jumped into this mod. Also, I just got 2 cheap propane tanks for the YJ, so it will be on pane and probably get built with higher compression for the pane.
What about the radiator? Am I gonna hate writing that check?
1989 YJ Islander
TBI350 4L60E BDS lift.
Wag axles, 38 TSL's, 4.56 gears
1995 ZJ Orvis Edition 5.2L
3" lift and 32's.
learfxr is offline   Reply With Quote
Old 09-25-2007, 09:55 PM   #2
Tomb Raider
MyJKRocks!
Shifter: Art carr shifter: $250 bucks
Radiator: Aluminum: $150 bucks(have to make mounts) or "conversion" rad: $225
2007 JK Unlimited Sahara
37" Irok ND's
4" rough country lift
Tomb Raider is offline   Reply With Quote
Old 09-25-2007, 10:01 PM   #3
learfxr
Unfortunately I already spent the $ on a B&M when I put the 727 in. It sucks, but that's just more money to spend to replace it right now. Hope it works on the Chevy, it had several applications and I think I kept all the little brackets.
Where can I pick up the $150 rad? I can figure out the mounts I hope.
Thanks for the info
I know I should be using search more, but it kept acting up earlier when I was looking for what mounts to order, I knew I read about the mounts but forgot who had good ones.
1989 YJ Islander
3" lift and 32's.
Old 09-25-2007, 10:02 PM   #4
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
axles? might as well just give me the small block......
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Old 09-25-2007, 10:06 PM   #5
learfxr
Well, those will just have to stay for a bit. They just got geared and locked, no way am I ready to pay to gear another set of axles.
I'm usually pretty calm with the throttle, so maybe I can make them last. They are D44 and AMC20 from a Waggy.
1989 YJ Islander
3" lift and 32's.
Old 09-25-2007, 10:10 PM   #6
learfxr
You just did your 4.0L swap, no more engines for you this year. lol
1989 YJ Islander
3" lift and 32's.
Old 09-25-2007, 10:16 PM   #7
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
haah, i'll wait until january for it
you should be fine with those axles if you drive with sense.
pictures will be required, by the way....
Old 09-25-2007, 10:17 PM   #8
1 ton yj
Thanks for the info
x2 for the Art Carr. Worth every penny. Put your B&M on Ebay.
As for the radiator, get any Chevy style 22x19 in your favorite catolog (Summit, Jeg's, ect) and make your own mounts.
What case did you get? Most fullsize Chevy cases are clocked way too low to be used in a YJ.
1 ton yj is offline   Reply With Quote
Old 09-25-2007, 10:26 PM   #9
learfxr
I hope it fits, I think it's a 205. I'll pick it up tomorrow. Guess I can see what else will work. No money for an Atlas or anything.
1989 YJ Islander
3" lift and 32's.
Old 09-25-2007, 10:31 PM   #10
1 ton yj
One of my friends has a clocked flat 205 so it is possible, but I think he's got quite a bit of time invested in it. If you don't want to go through that much work, try an upside down D300. Great case, easy to adapt to a Chevy trans and you can build it as you go.
Old 09-26-2007, 02:28 PM   #11
learfxr
Ok, I've got some reading to do. The trans case that came with the package deal is a NP203. It's a beast. My problem is my front D44 is from a Waggy, and is driver side drop, the 203 is passenger. I could have gotten the front D44 the guy has, but I just paid to have mine geared and locked. I need to research if my Jeep NP208 will work on the TH350 trans. My fingers are crossed.
1989 YJ Islander
3" lift and 32's.
Old 09-26-2007, 03:00 PM   #12
learfxr
Here's the first pics. Getting it all unloaded from the trailer.
Here's the T-case that will be for sale soon. NP203
1989 YJ Islander
3" lift and 32's.
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
