Yay or Nay - Lunchbox Locker with TJ Passenger Shaft??? - JeepForum.com
post #1 of 29 Old 01-15-2014, 03:18 PM Thread Starter
StanF
The title says it all "Yay or Nay - Lunchbox Locker with TJ Passenger Shaft???"
I'm changing transfer cases and will lose the transfer case vacuum switch (and CAD) as a consequence (maybe a benefit?). I have a Lock Right lunchbox locker in my Dana 30.
I'm interested in the one-piece TJ passenger side shaft as a solution. I'm worried that the TJ shaft may hurt the on-road manners of my Jeep because of the Lock Right. I'll basically be driving on just dry roads - very little rain and no ice or snow.
Yay or nay???
Just in case this comes up:
I don't really want to spend $150-200 on a Posi-lock system. I also don't really want to home-brew the Posi-lock.
Yes, a selectable locker would be best, but that's not my question! Also, selectable lockers aren't $250 like the lunchbox lockers - they're about $1000 more!
StanF is offline
post #2 of 29 Old 01-15-2014, 03:43 PM
jokerchief462
That's my setup and no issue in 2H. It will clunk once in awhile but good road manners.
Excellent off road and yes it takes a little getting used to but no issues.
Once you get lockers you will never go back the pull of the front axle is awesome.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 29 Old 01-15-2014, 03:53 PM
jbolty
jbolty's Avatar
you will not even notice it
jbolty is offline
post #4 of 29 Old 01-15-2014, 03:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Do it and don't look back
Luck Favours The Prepared
Anticanman is offline
post #5 of 29 Old 01-15-2014, 04:58 PM
JFranko
I have the exact same setup on mine, and I am extremely happy with it. My Jeep rides well enough at 75mph, and in 2wd it isn't noticeable. The only things to keep in mind are that turning in 4wd will be a little more difficult, and you may need to balance your front driveshaft (or use this as an excuse to get a HD one built).
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline
post #6 of 29 Old 01-15-2014, 05:24 PM
Shadownwpa
... so much for me having my mind made up to get '95 shafts and keep the cad/posi-lock.
Shadownwpa is offline
post #7 of 29 Old 01-15-2014, 05:46 PM
imstillatwork
Very occasional clunk at low speeds and very tight turns.
It was every day for about a week, then settled in to just now and again.
imstillatwork is offline
post #8 of 29 Old 01-15-2014, 05:49 PM
PA_YJ19
I have a spartan locker up from and tj shafts, I don't even notice it. Only clicking ull here is in the first couple hundred miles while the springs get broke in. After that mines been quiet as a mouse. No vibes or driving issues.
PA_YJ19 is offline
post #9 of 29 Old 01-15-2014, 08:36 PM Thread Starter
StanF
7 Yays...0 Nays....I'm convinced...
I know I can use a TJ shaft, but I'll have better luck finding an XJ shaft in the junkyard. I have a 95 with the larger Ujoints that I want to keep - what year XJs would be compatible?
StanF is offline
post #10 of 29 Old 01-15-2014, 09:08 PM
linusb
Add Nother yay.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #11 of 29 Old 01-15-2014, 10:01 PM
Shadownwpa
I was gonna do the 95 yj shafts for the bigger joints, but not being sure the cad on mine actually works I had considered the solid tj or xj shaft. I'd also like to know what years of those have the larger joints... expecially if it isn't gonna suck as bad as I thought on the road.
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
post #12 of 29 Old 01-15-2014, 10:52 PM
JFranko
All ABS cherokees, and 95+ cherokees have the larger u-joints.
JFranko is offline
post #13 of 29 Old 01-16-2014, 03:14 PM Thread Starter
StanF
I found this article to be pretty interesting:
http://www.fourwheeler.com/how-to/tr...ee-axle-guide/
It sounds like 1996-2001 XJ shafts will work.
But there was this one interesting comment:
"There was a ¼-inch change in the unitbearing flange-to-flange depth that can cause interference issues between the rotor, caliper, and even the face of the knuckle. It is typically safer to just take all the parts from the donor, however we have had luck mixing and matching parts."
StanF is offline
post #14 of 29 Old 01-19-2014, 01:05 AM
CreOli
Have a lock right and chromoly shafts with the cad delete....love it not even noticable except a lil noise every once and a while during a tight turn. Gets a yayyyyyy from me....
CreOli is offline
post #15 of 29 Old 01-19-2014, 06:55 AM
ahar9
Not trying to hijack but if I put shafts from my 98 xj on a 94 yj would the yj need a different tcase? Or would I just take the vacuum line off and keep the same tcase?
hold my beer
ahar9 is offline
