XJ water pump on our YJ? - JeepForum.com
post #1 of 10 Old 02-23-2010, 11:01 AM Thread Starter
czjeeper
Hey all.
My brother's '93 (stupid thing) is finally running now.
Problem is, it's running hot.
I'm going to install a Taurus E-fan to replace the hot pink "racing" fan the PO installed.
Space is very tight w/the 4.0.
I remember reading somewhere that you can install an XJ water pump and pulley because they don't stick out as far.
I think there was a specific year because of the reverse rotation or something.
Anybody know anything about this?
Thanks!
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 10 Old 02-23-2010, 06:45 PM Thread Starter
czjeeper
Bump for more looks.
I got the an XJ water pump pulley, and it is thinner than the pulley on my 2.5.
US Army combat vet
czjeeper is offline
post #3 of 10 Old 02-24-2010, 11:01 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
If it is shorter, the w/p pulley may not line up with the other pulleys.
5.7YJ is offline
post #4 of 10 Old 02-24-2010, 11:22 AM
Leans93
She's my density...
Leans93's Avatar
I run an XJ waterpump in my 93 YJ. 91'-95' with serpentine belt have the same rotation and will work for sure. I have posted info and pics in the 2 threads below.
http://www.jeepforum.com/forum/f12/t...ld-fan-957598/
http://www.jeepforum.com/forum/f12/l...e-pics-668796/
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #5 of 10 Old 02-24-2010, 02:20 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Nice job on the swap. I see you used all of the brackets and accesories from the Cherokee so all would be fine. If the Cherokee w/p is indeed shorter as the OP thought and he is using his brackets from the Wrangler engine, they might not line up.
5.7YJ is offline
post #6 of 10 Old 02-24-2010, 03:02 PM
Leans93
She's my density...
Leans93's Avatar
Actually all the brackets are from a YJ, the only XJ specific part left is the waterpump and pulley. It bolts right up and lines up with the serp belt perfectly.
M.F. Leans
Leans93 is offline
post #7 of 10 Old 02-24-2010, 03:21 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I didn't know that, learn something new every day! So I guess the OP won't gain much space then or does the pump just not have the shaft sticking out for the mechanical fan?
5.7YJ is offline
post #8 of 10 Old 02-24-2010, 03:29 PM
jbolty
jbolty's Avatar
Pictures?
The fan bolts to the same studs that hold the pulley on. For a taurus swap take out the studs and use button head allen bolts.
Also, take the taurus fan off the shroud and cut down the electric motor mounting lugs to gain about 3/8" of room.
jbolty is offline
post #9 of 10 Old 02-24-2010, 04:32 PM
Leans93
She's my density...
Leans93's Avatar
You will gain extra room, I'd say around 2" give or take. The XJ fan is not located on front of the water pump therefore the shaft is shorter and the pulley is flat as opposed to the YJ that has the fan on the same pulley and the water pump shaft is longer.
M.F. Leans
Leans93 is offline
post #10 of 10 Old 06-15-2016, 11:10 PM
95dustinyj
Water pump pulley
I have a strait six looks like my fan pulley sticks out to far. Do I have the right pump and pulley belt slips off.
95dustinyj is offline
4.0 Water Pump Pulley Seized onto water pump grAmit TJ Wrangler Technical Forum 9 09-09-2009 04:17 PM
I think I want a water pump... kaybone TJ Wrangler Technical Forum 12 01-16-2008 05:39 PM
Water pump?! blase116 TJ Wrangler Technical Forum 11 07-27-2007 01:49 AM
water pump help Desert Safari TJ Wrangler Technical Forum 3 05-06-2005 10:56 PM
New Water Pump Jordan99TJ TJ Wrangler Technical Forum 3 05-20-2003 05:53 PM
