Xj tranny in a yj - JeepForum.com
post #1 of 11 Old 09-22-2013, 08:39 PM Thread Starter
colenoah8
Xj tranny in a yj
Alright so my yj clutch is about to take a dump on me (internal slave) and I've been thinking about how to fix the situation. I've got two, 2wd xjs that I do not use, one is a 1998 and one is a earlier 90s model, not sure exactly, they both have auto trannys. And I had a random though of swapping those into my 1990 4.2 yj. Would this work? Or would it not even be worth messing with?
My jeep at one time had an auto tranny, but someone swapped it over. (It's still registered as an auto)
colenoah8 is offline
post #2 of 11 Old 09-23-2013, 09:14 AM Thread Starter
colenoah8
Anyone?
post #3 of 11 Old 09-23-2013, 09:16 AM
grandboost98
Im not sure about the autos but I know if you switch a 4wd manual ax15 from a cherokee to a yj you have to clock the output flange so the transfer case sits right.
Sorry I couldnt be of more help
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is online now
post #4 of 11 Old 09-23-2013, 10:42 AM
instg8tor
its been done before, search on AW4 in YJ or TJ. There's lots of write ups.
It works well, the AW4 is about an inch longer than the AX15, you'll need to extend/shorten the drive shafts, rework the transmission mounts and splice in the transmission controller.
'91 Renegade - Waggy 44/20 (F/R Aussie) SOA, E350 MC, York OBA, Custom F/R bumpers
instg8tor is offline
post #5 of 11 Old 09-30-2013, 09:09 PM
94jeepman
2005 WK
I had a auto in my jeep never ran the wires to the tcm thos so I had to shift manually. and my jeep is still registered as a 4 cyl haha
94jeepman is offline
post #6 of 11 Old 09-30-2013, 09:53 PM Thread Starter
colenoah8
What do you mean shift manually?
post #7 of 11 Old 09-30-2013, 10:47 PM
94jeepman
2005 WK
like a slap shift type then I would have to put it in 1st, 2nd, 3rd, then drive
post #8 of 11 Old 10-01-2013, 07:22 AM Thread Starter
colenoah8
I kind of like the idea of that..
post #9 of 11 Old 10-01-2013, 11:58 AM
superj
ha ha ha, slap shift auto would be hilarious for a thief. but i bet its would get old
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #10 of 11 Old 10-01-2013, 03:37 PM
94jeepman
2005 WK
The only thing bad about the about it was that the 1st and 2nd gear are in the same thing kind of so it actually goes 1st to 3rd second gear is controlled by the computer so if you put it in 1st when your off roading with the computer it will shift into 2nd. But I would suggest wiring it up if you can
post #11 of 11 Old 10-01-2013, 08:01 PM
Mark05059
I wouldn't even think of doing that swap... 2wd auto tran would have to come completely apart and have the output shaft changed... not a good swap at all... look for a 4wd trans and yeah a much better choice.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
