xj style - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > xj style
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 04-02-2002, 12:31 AM   #1
rollinashortysahara
xj style
ok what do you think of running the black diamond coil conversion up front and soa in the rear w/ dana 44s what size tires do you think i could run what else would i need to run 35s and get full flex out of it (tj flares are already planed on)
rollinashortysahara is offline   Reply With Quote
Unread 04-02-2002, 11:55 AM   #2
V8wrangler_idaho
why don't you do the coil spring convertion frount and back?? but that shoudl work fine to get more travel out of the back you could put some revlovers shackels on the back.
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline   Reply With Quote
Unread 04-02-2002, 09:46 PM   #3
rollinashortysahara
yeah i'm just cheap sorta and i noticed the yj rears with soa can stuff a tire in the fender well before the front will so i figured get a nice ride and saev some money
