XJ springs - JeepForum.com
post #1 of 10 Old 05-04-2010, 07:31 AM Thread Starter
hesserdude07
XJ springs
hey guys, i have a mostly stock suspension setup. I just got given a set of XJ rear springs with a 2" add a leaf in them. What is my best best on doing something with them for my jeep? I want a beefier spring for the front of my jeep as my HEAVY bumper and winch... Any help would be great!!
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #2 of 10 Old 05-05-2010, 07:11 PM Thread Starter
hesserdude07
any answers guys?
post #3 of 10 Old 05-05-2010, 07:39 PM
JohnFM3
I am not 100% certain on this, but I think the only reason for using the XJ springs is when used to push the rear axle back. I think you gain almost 6 inches of wheel base length.
I am not sure of any real benefit to running XJ leaf springs.
John
John Moore ~ Real Men Still Crawl...
97 XJ (Diablo) 4.0L H.O. w/AW4 4sp Auto Dana 30/Chry 8.75 2.5 inch Flowmaster Exhaust 4 inch Lift w/ 32inch tires & RS5000 Shocks
92 YJ (BOSS) 4.0L H.O. w/AX-15 5sp Manual, 231 TCase, Dana 30/8.8 (3.73) 2.5 inch Flowmaster R.E. 2 inch lift and 2 inch body lift for CJ clip
XJ
YJ
JohnFM3 is offline
post #4 of 10 Old 05-05-2010, 10:29 PM
Checo18
It's true that using xj leafs will push back the axle I don't know how much for sure either : /, but realize if you try to put those on with out the proper mods you'll run into all kinds of clearance issues.
_______ Only in a YJ
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
2.5L, 4" RE lift, 1" booms on the front, Revolvers on the back, 1" B.L., Aussie in the 35, 31" Trxus tires, Gen-rite rocker guards, BTF tube fenders, Pro Comp bumpers, KC lights, Hi-lift and a whole lot of love.
Checo18 is offline
post #5 of 10 Old 05-06-2010, 06:53 AM
Brads_nky_yj
You'll need to do something about your rear gas tank, extend your driveshaft/brake lines.
I got 7" of stretch using ruff stuff perches with the extra center pin hole. I gained almost 15" of wheelbase stretch by using xj springs front and rear.
They are super soft, only downfall. make sure you beef em up or add an extra main spring to the pack. Also with the 2" add a leaf SOA it will be super tall. Sua with that set up would work super nice.
93 YJ - SOLD
Brads_nky_yj is offline
post #6 of 10 Old 05-06-2010, 07:18 AM
jeep795
Well, he said he wanted it for the front... You get into all sorts of issues up there. You have to move the rear frame hanger, and mess with steering, cause it'll push the axle pretty far forward. I don't think it would make for a more heavy duty spring that stock yj springs. Stock yj springs are pretty stiff, xj springs... kinda squishy, especially with the weight of a motor on top of them. In the front i think they'd settle too much, too fast.
jeep795 is offline
post #7 of 10 Old 05-06-2010, 07:22 AM
Brads_nky_yj
you dont have to move the rear frame hanger at all. You just have to do something with your front shackle hanger. I bought way back hangers from ruff stuff and put em on the front of my bumper, I used an astro van steering box with a reverse steering arm and added 2 more springs to my front pack. no problems. you just gotta know what your doing and what to do if you do run into problems.
93 YJ - SOLD
post #8 of 10 Old 05-06-2010, 05:31 PM Thread Starter
hesserdude07
well i already did move my axle backwards on my stock rear springs when i did my 8.8 swap. Just been looking for a few inches of lift. Dont feel like buying a lift kit...Im to POOR.
I flat fender'd my front already, doing comp cut rear corners now. Just wanna gain about two inches out of junk yard stuff. Like to make my own **** instead of buying.
post #9 of 10 Old 05-07-2010, 12:09 AM
Brads_nky_yj
Go to the junk yard and grab some full size waggy springs. Combine them with your YJ springs to make the perfect lift height. Then put them in there. You wont have to change anything...anything...and they usually net about 3" of stretch.
You wont have steering problems and you'll gain a bit of stretch.
If you use the xj springs in the front you'll need to spend some money to do everything right. But not too much.
93 YJ - SOLD
post #10 of 10 Old 05-07-2010, 12:50 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Put the crack pipe down and stop listening to mysterious voices in your head.
Joe Dillard is offline
Rubi springs VS stock Sport springs seekrtruth TJ Wrangler Technical Forum 12 08-22-2009 08:58 AM
2.5 Lift, can I replace the springs with 4in springs? Rippers TJ Wrangler Technical Forum 3 05-30-2009 08:41 AM
How do lifts perform? BB/ZJ springs/Lift Springs? TJ_ITmgr TJ Wrangler Technical Forum 3 10-27-2007 01:14 AM
Comparing XJ Springs to YJ Springs - Height Question Big-n-Broke-YJ YJ Wrangler Technical Forum 16 03-11-2007 01:56 PM
Replace Stock Springs with Rubi Springs NewBinCO TJ Wrangler Technical Forum 9 09-01-2006 11:33 PM
