XJ shaft conversion question - JeepForum.com
post #1 of 12 Old 12-19-2009, 01:21 PM Thread Starter
czjeeper
I have my big joint XJ axle shafts in had, ready to install.
I need to get the seals, and am going to fabricate a vac. housing cover.
Does anybody have the dimensions of the housing?
Is there a gasket available that I can use as a template?
Thanks!
Also, can anybody verify that a National seal # 710068 will work for the seal on my passenger side carrier?
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 12 Old 12-19-2009, 01:26 PM
timatoe
timatoe's Avatar
I pulled mine off, pulled the fork out and layed it flat on a piece of scrap, traced it out and cut it.
timatoe is offline
post #3 of 12 Old 12-19-2009, 01:26 PM
iowajeepers
Thanks!
I just made a cardboard template using the vacuum actuator.
1994 YJ, 2004 WJ, 1976 C3, 2015 Slingshot, 2001 ZX6r
iowajeepers is offline
post #4 of 12 Old 12-19-2009, 04:58 PM
dand3053
I just took the fork off and reused the original housing as a block off.
dand3053 is offline
post #5 of 12 Old 12-19-2009, 07:18 PM Thread Starter
czjeeper
That's a good idea too.
I have a Posi-Lok, though, and I'm going to sell it when I swap.
US Army combat vet
czjeeper is offline
post #6 of 12 Old 12-19-2009, 07:28 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
I am curious. By doing this will this not make it so that your front driveline will spin while driving, causing vibrations since the front driveline is not balanced. Also won't this cause some issues for the transfer case as well?
I know that around 55-60 when I have my hubs engaged it does this on my jeep and it can't be good on the t-case. - I don't do this often or on a regular basis either.
Back Road Jeepin
BackRoadJPin is offline
post #7 of 12 Old 12-19-2009, 07:45 PM
iowajeepers
Mine does 70mph with the solid axle configuration and no noticeable vibrations.
However, I did stretch a front drive shaft from an XJ to replace my stock front YJ shaft.
post #8 of 12 Old 12-19-2009, 07:47 PM
BackRoadJPin
1995 Wrangler
I think the XJ shaft is balanced as they run this very setup already. I am just curious, I had entertained this same idea then opted for D44's and SOA instead.
Back Road Jeepin
post #9 of 12 Old 12-19-2009, 07:52 PM
iowajeepers
Yeah, that's why I went with it, since the XJ's already did. Although clearance was close. I self-cleared my front exhaust pipe and the new drive shaft. Happened at full stuff.
post #10 of 12 Old 12-19-2009, 09:02 PM Thread Starter
czjeeper
When I had my front driveshaft rebuilt last winter, I had them balance it because I was planning on this.
US Army combat vet
czjeeper is offline
post #11 of 12 Old 12-19-2009, 11:20 PM
whitie_08
how do you get the fork out?
^^^thats a lie.
whitie_08 is offline
post #12 of 12 Old 12-20-2009, 06:35 PM
1tuffyj
u dont have to take the fork out. just take the collar off and toss it. the xj shaft isnt big enough to touch the fork with no collar there. mines been like that for yrs now no issues. and yes, u need to have the front shaft balanced or it will cause vibes.
the pressure makes us stronger, the struggle makes us hunger, the hard lesssons make the difference, and the difference makes it worth it.
1tuffyj is offline
How-To: TJ Axle Shaft Conversion H3RTCH YJ Wrangler Technical Forum 117 06-24-2017 02:37 PM
TJ axle shaft conversion in YJ YJ_Aaron YJ Wrangler Technical Forum 28 05-26-2011 11:50 AM
Currie Tail Shaft Conversion? njbowhntr TJ Wrangler Technical Forum 4 05-10-2009 08:52 AM
YJ using XJ front shaft for 8.8 conversion 72cj5er YJ Wrangler Technical Forum 4 03-17-2007 05:33 AM
TJ axle shaft conversion? Lavacrawler YJ Wrangler Technical Forum 16 01-02-2004 09:39 AM
