XJ HVAC system in YJ.....Lets try it.. - Page 9 - JeepForum.com
post #121 of 134 Old 09-19-2012, 10:56 AM
Que89YJ
Its looking great.
Que89YJ is offline
post #122 of 134 Old 11-29-2012, 07:24 PM
Dre40
Hey so how you coming along on this swap?
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #123 of 134 Old 11-30-2012, 05:28 AM Thread Starter
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
Slow, Very slow. I mean it will not be done until I finish wiring the whole Jeep. I have been too busy working on everyone elses stuff, and making my motor mounts, visiting family, I rebuilt an 06 F-150 recently for some extra cash, yadda yadda....
This Sunday is the first day in probably a month I hope to even touch it haha. I hope to get her started Sunday. Maybe I will have some news on Monday.
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #124 of 134 Old 01-07-2013, 12:52 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
So I got the HVAC unit working yesterday!!
When I say working, the blower motor runs, and adjusts speeds with the control switch. I did not have time to try anything else, but since this things is pretty "standalone" all the vacuum controlled stuff should work.
I still have to work out how to get the AC system to work though.
post #125 of 134 Old 01-07-2013, 07:21 PM
jmmorgan82
2009 JK Wrangler
Excellent news. Keep us updated!
jmmorgan82 is offline
post #126 of 134 Old 01-08-2013, 03:08 AM
Que89YJ
Lol still following your thread but it is hard to be as enthusiastic with the mercury hitting 20!
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #127 of 134 Old 01-08-2013, 05:46 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Thanks,
Well it is not that cold here! But at least my heat works, I have "bigger fish to fry" before I get the AC working.
post #128 of 134 Old 07-10-2013, 08:10 AM
snail81
progress?
snail81 is offline
post #129 of 134 Old 07-15-2013, 08:42 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
well, all the vacuum operated stuff works as it should. All I need to do now is mount a compressor and plumb everything.
I have just been way too busy with re-building a boat, building a CNC plasma table, designing/building a press brake, designing other peoples stuff, and designing a sheetmetal dashboard......
The Jeep has been neglected....
post #130 of 134 Old 08-18-2013, 05:44 PM
Johnfire
I am looking to do the same, how did you work out the wiring to make it standalone. My option is to pull from a junkyard, and had been working on getting one out when I ran into one problem getting it out clean so I stopped and figured I would come back to it, or start over on another vehicle. Just a little worried on being able to wire it to work correctly since I have never messed with this kind of a setup.
Johnfire is offline
post #131 of 134 Old 08-19-2013, 06:02 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
This system electrically is basically just a blower and a speed resistor, and then a few switches for AC component control.
I should have documented what wires went where a little better, but it really only was a few. I bought wiring diagrams for both vehicles from alldatadiy.com that really helped.
If you pull from a vehicle, you have to take your time to get ALL the components and wiring harnesses that go along with it.
post #132 of 134 Old 01-28-2014, 10:23 PM
twiisted71
YJ I'd love to see the interior with the controls and outlets. Also do you have a ballpark figure on that sheet metal firewall scab's cost? Cherokees are one of the least picked over vehicles in any yard you go to. I've been trying to come up with a cable operated system since I'm not going to have vacuum.
You still making mounts? I've sent a dozen or more folks your way! You need to come up with a TJ set now that they are getting more common in the used/abused market. More and more people are asking for mounts. Many are using the Jeff D, flat style isolators with simple angle iron brackets.
twiisted71 is offline
post #133 of 134 Old 01-29-2014, 11:15 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Man, I have been so busy designing stuff for other people, my dashboard project got put on hold, I did build my press brake though. It has been a little cold and snow in PA too to be working on the Jeep much since I do not currently have a garage to work on the Jeep in.
I am also helping a buddy do a 350 swap into a TJ, so I may try to take a ton of measurements off of his frame and design some mounts, but I do not want to sell them until I have installed and used them myself, and I just do not have the budget or time to do a 4bt swap into a TJ right now.
The sheetmetal for the firewall cost like $80 I think. I am not sure if the older Cherokees had cable operated HVAC controls. But there is a TON of useful stuff on junkyard Cherokees. I have yet to ever see a YJ in a junkyard.
This is getting off track of this thread slightly, but yea I am still making YJ mounts, thanks for sending people my way! I am actually working on a new batch right now finally. I should have some ready in a few weeks.
Jeff D is probably making a killing off their mounts, I know how much it costs them to produce those, about 1/4 of what it costs me to make mine, and they still sell them for much more than I do. I REALLY wish I had the chance to compare engine vibes in my YJ w my mounts compared to theirs, id buy a vibrometer just to prove my mounts absorb vibes better. I have my electric vacuum pump mounted on the firewall (with little rubber isolators) and the vibrations that that little thing makes are like 5 times more than the engine vibes! Now, those vibes are definitely amplified by the sheetmetal, but, you get what I am mean. I designed my mounts specifically to absorb vibration and be bullet proof, Jeff D designed them to be cheap and easy to make, "fit all", and then threw some liquid isolators in there to try to absorb vibes...... I would be willing to bet their bent plates flex quite a bit as well, and I would not feel safe supporting 750lbs with them....
Wow, I really babbled on there....., sorry guys.
post #134 of 134 Old 01-29-2014, 05:48 PM
twiisted71
Yeah I can't believe people don't get that they could just buy a couple of pieces of 6" x 1/4" angle iron and some cheap marine engine mounts and have exactly the same thing as the JD mounts! They just have some nice slots burned in the plates! Ah well it stimulates the economy!
Glad to hear you have more work than you can handle! Don't complain too loud
air flow control door in the HVAC system LiveAndLearn TJ Wrangler Technical Forum 4 10-02-2010 06:33 AM
vacuum system hoses all hooked up but system doesnt work snowcrawlr619 YJ Wrangler Technical Forum 8 12-28-2009 07:52 AM
Asking for HVAC help.... sandmangreg TJ Wrangler Technical Forum 3 08-19-2008 10:00 PM
Need HVAC help clhman TJ Wrangler Technical Forum 1 02-01-2008 04:05 PM
hvac system dosen't work?? drew76924 TJ Wrangler Technical Forum 3 10-30-2006 11:15 AM
