XJ HVAC system in YJ.....Lets try it.. - Page 8 - JeepForum.com
post #106 of 134 Old 06-14-2012, 11:08 AM
crackedcornish
when I first saw the size of the holes you had to cut, I figured it was going to end up as a hacked up mess, or it was just not going to get finished at all....but I have to admit, I was totally wrong. That firewall work looks really good...keep it coming, it's great info. and your making some real progress
I do have a question though, do you think if you had had the time/tools/space, it would have been better to cut out the Cherokee firewall and try and graft that into the YJ's firewall, or would you still have done it the way you did with the fabricated cover??
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #107 of 134 Old 06-14-2012, 11:42 AM Thread Starter
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
No going to lie, so did I..... especially with a flux core 110v welder on sheetmetal....you know your a bad welder when you get to be really good with an angle grinder...
That is a good question. If I had enough time, and battery life on a saw-z-all it probably would not be bad to cut out a cherokee firewall to graft it in. next trip to the junkyard I will take a second look at it.
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #108 of 134 Old 09-04-2012, 06:05 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Finally fabbed up a new battery tray!
post #109 of 134 Old 09-04-2012, 06:07 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
just realized those pics are mid-process, dont worry I added more bracing, it grabs 4 bolts in all and is nice and solid. Also made a mount for dual power distribution boxes.
post #110 of 134 Old 09-04-2012, 07:34 AM
crackedcornish
glad to see this project hasn't died out!
post #111 of 134 Old 09-04-2012, 07:40 AM
Doch80
_______
/I ,[_____],
IóL --[]IIIIII[]--
()_) ()_)-o-()_)
Doch80 is offline
post #112 of 134 Old 09-04-2012, 09:55 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Not yet, I am just slow working ..... Wiring this thing is taking me a VERY long time,
one more thing though, after much thinking this weekend and failed attempts at running ducting from the stock intake (between the hood and windshield) to the intake of the AC housing.....I stepped back and thought "how important is it to me that I have a fresh air intake, I would rather run the AC recirculating the cold air inside anyway, If I realllly need fresh air, I can open a window...."
So I also cut out a cover plate for the air intake, I will get pics tonight, its hanging in the garage drying.
I plan to just put a screen over the AC box housing intake, and let it draw air from under the dash...can anyone see a problem with this?
Its slow progress working in a driveway with limited tools....I have to use my bumper as a sheetmetal break
post #113 of 134 Old 09-04-2012, 10:14 AM
Que89YJ
Glad to see you are pushing ahead. Nice job of welding on the tray.
Que89YJ is offline
post #114 of 134 Old 09-04-2012, 10:24 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Thanks,
Meh, it kinda sucks knowing what I can do with a nice MIG welder, and having to use a crummy flux cored welder that leaves flux dust and spatter everywhere, it works, but my welds are not the prettiest...
post #115 of 134 Old 09-04-2012, 10:32 AM
dodger889
There are times that like defogging the window that you would use the fresh air intake for. Then you have to think about winter time and you happen to bury the tail pipe in snow you would want fresh air to come in to pressurize the interior keeping the exhaust fumes out. Or those days that it just chilly out but you still want a little air coming in. Those are a few reasons to have the fresh air hooked up.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #116 of 134 Old 09-04-2012, 11:20 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
hmm, true..... not quite enough for me to change my mind though, seems few and far between, I am an open window kind of guy even in the winter, and I have never had a case where fumes inside have bothered me.
The defogger may not work as well, but should still work.
I know I can run ducting, but I do not have enough room to create a drain as well to be sure it does not suck water in... it seems like a lot of work for something that I may not need, then again....did I really need AC and a new dash?
post #117 of 134 Old 09-05-2012, 10:10 AM
Que89YJ
LOL. Global warming... you are just being prepared!
Que89YJ is offline
post #118 of 134 Old 09-05-2012, 11:25 AM
Louie4
I like it. I am looking forward to the finished product.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #119 of 134 Old 09-06-2012, 07:04 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
As far as the AC goes, next I need to start thinking about AC lines, mounting a condenser and fan, and a drier.
I would like to find a small universal condensor, and electric fan. I am thinking about mounting the condenser under the battery, and cutting a hole in the side of my fender, like those Gen-Right fenders, and installing a vent, and have the fan pull air in from the side. Hopefully I can get enough air flow.
I have made custom AC lines before, but using a line crimper that belonged to Novak when I was there, those crimpers are expensive! Any other ideas on custom AC lines?
post #120 of 134 Old 09-19-2012, 10:20 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Not much of an update, but I got my vent cover on. As you can see, it has been raining just about every day after work the past few weeks, so I have not made much progress. I had just enough time to bolt this thing down and snap a picture before it poured.
air flow control door in the HVAC system LiveAndLearn TJ Wrangler Technical Forum 4 10-02-2010 06:33 AM
vacuum system hoses all hooked up but system doesnt work snowcrawlr619 YJ Wrangler Technical Forum 8 12-28-2009 07:52 AM
Asking for HVAC help.... sandmangreg TJ Wrangler Technical Forum 3 08-19-2008 10:00 PM
Need HVAC help clhman TJ Wrangler Technical Forum 1 02-01-2008 04:05 PM
hvac system dosen't work?? drew76924 TJ Wrangler Technical Forum 3 10-30-2006 11:15 AM
