XJ HVAC system in YJ.....Lets try it.. - Page 6 - JeepForum.com
post #76 of 134 Old 01-08-2012, 01:41 PM Thread Starter
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
a few more pics
407362_10150451145267583_687697582_8932136_347864905_n.jpg   387432_10150451147527583_687697582_8932157_1380260335_n.jpg
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #77 of 134 Old 01-08-2012, 03:30 PM
dodger889
Hmm Where does the fresh air inlet on the unit? Man that is a big hole. I see sheet metal works in you future. You want a custom dash now you will have a custom fire wall too. Also you might want to go ahead and cut out for the blower motor to be able to be replaced.
Just a crazy thought here. I wonder if it would be easier to cut that area of a xj firewall out and install that in your YJ.Since it is formed for the AC already??
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #78 of 134 Old 01-08-2012, 04:31 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
The fresh air inlet is all the way to the pass. side, the same as the YJ, but the ducting for the YJ will not work. So I am going to have to design a sheetmetal duct as well.
The hole definitely ended up a lot larger than I expected, but it can all be covered with new sheetmetal. I kinda just kept hacking til it fit.
The XJ firewall might not be a bad idea... I will have to look at one closely
Right now, what will probably be easiest for me is to take good measurements and design a new section of sheetmetal for the fireall. I do not have any real sheetmetal fab tools, so the best way for me to do it is to get it laser cut.
I agree on making the hole big enough to get the blower motor out, I was just happy to see it fit today.
I also tore out all the old hacked wiring, hopefully I will get some time to work on the harness this week.
post #79 of 134 Old 01-08-2012, 04:37 PM
twiisted71
wow thanks for the pics. that is too much of a misfit for the mods I'm already going to be doing without a major (for me anyway) sheetmetal work.
twiisted71 is offline
post #80 of 134 Old 01-08-2012, 05:39 PM
Dre40
WOW look at those holes lol.. I wounder if an XJ firewall would work sounds like a good idea. the hard part would be cutting it out at the pick and pull..
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #81 of 134 Old 01-09-2012, 05:32 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
I know, and I still need to cut more.... I need some sheetmetal practice anyway haha. It is turning into way more of a project than I planned, but hey, when is anything ever as easy as it seems.
I dont think my saw-z-all battery will last long enough to cut out the XJ firewall at the pick and pull haha, but it is definitely a consideration, especially since I still have no idea how I am going to measure to drill the mounting holes, there is just no good datum point on this thing....
I suppose I will see next weekend...
post #82 of 134 Old 01-09-2012, 06:07 AM
twiisted71
Get a cheap thing of lipstick in a bright color that contrasts your jeep. Smear it on the ends of the mounting bolts and all you have to do is touch it to the fire wall. When you pull it back down the bolt locations will be marked.
post #83 of 134 Old 01-09-2012, 06:19 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
I thought of something like that, I just hope I can muscle the thing up there, and push it into the firewall close to where I want it without moving it and smearing lipstick all over haha.
I think my girlfriend did get bright red lipstick for christmas.... she'll never miss it...
post #84 of 134 Old 01-10-2012, 07:19 AM
ROWA
ROWA's Avatar
Youngjeeper11,
You might need to make a cardboard mockup of the Heater/AC unit with the bolt holes and pluming cutout's. Can you lower the whole unit until the AC drain is right where the floorboard to firewall meet? This would give you a little more room to make up the fresh air intake.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #85 of 134 Old 01-10-2012, 07:43 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Ya I will probably end up doing somthing like that.
I do not want to move it any lower because then it starts to get into the passenger foot room, it is already about an inch lower than the stock unit is.
post #86 of 134 Old 01-16-2012, 03:08 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
more cutting today. I finally ended up just cutting a big ole' hole to make it easier to fill in later. Working on a sheetmetal design as I post this.
I also mocked up the water valve, but I am not really happy with it.
Last, I mounted my vacuum tank....thing, whatever it is called on the inner pass. fender
O and the lipstick worked great, I drilled the mounting holes as well
post #87 of 134 Old 01-16-2012, 04:08 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
and viola...
post #88 of 134 Old 01-16-2012, 05:24 PM
twiisted71
De nada. I'm kinda like Cliff Claven (Cheers fame). I'm full of great knowledge, not neccesarily useful knowledge.
now you need to pop out a couple of those HVAC adapter boxes for those of us who HATE sheet metal work.
post #89 of 134 Old 01-16-2012, 06:29 PM
dodger889
I see that gives you some more room inside Cool ..... Also is that a mounting point by the fan cutout, just above the cool hose for the fan? If so that would not be hard to to do.
I see that you can still use the battery support bolt holes to remount the battery. Just have to use some sorta spacers. Nice!
post #90 of 134 Old 01-16-2012, 06:34 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
Hahaha, well it was useful for me.
Well if I get some interest I can make a few, but its still no easy task haha. This sheetmetal piece is still going to need to be welded in.
But I can easily get a few made if people want them.
air flow control door in the HVAC system LiveAndLearn TJ Wrangler Technical Forum 4 10-02-2010 06:33 AM
vacuum system hoses all hooked up but system doesnt work snowcrawlr619 YJ Wrangler Technical Forum 8 12-28-2009 07:52 AM
Asking for HVAC help.... sandmangreg TJ Wrangler Technical Forum 3 08-19-2008 10:00 PM
Need HVAC help clhman TJ Wrangler Technical Forum 1 02-01-2008 04:05 PM
hvac system dosen't work?? drew76924 TJ Wrangler Technical Forum 3 10-30-2006 11:15 AM
