XJ HVAC system in YJ.....Lets try it.. - Page 3 - JeepForum.com
post #31 of 134 Old 12-11-2011, 09:43 AM
1992 renagade
youngjeeper11 this guy put the whole XJ dash in a YJ but then the thread just died. Maybe worth checking out? http://www.jeepforum.com/forum/f12/8...16/index6.html
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications
Blue Mountain Jeep Alliance
Delaware jeep Association
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline
post #32 of 134 Old 12-11-2011, 10:32 AM
ROWA
ROWA's Avatar
youngerjeep11,
I scanned some of the wiring diagrams from the YJ and XJ hope this helps.
Did you check if the penetration for the heater and AC connections, interfere with the battery tray?
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #33 of 134 Old 12-11-2011, 06:29 PM Thread Starter
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
Wow, thanks for the help guys!! Seriously, I was not expecting so many great diagrams!
My printer at home is dead, so I am going to print all this stuff out at work, and hopefully sort some things out tomorrow night.
I think the wiring for the AC between a YJ and XJ is similar enought that it should not be too bad.
From my eyeballing and quick measurements the a/c and heater lines should clear to the inside of the battery tray.
Still waiting for my saw-z-all to come so I can actually start doing some surgery....
still going to try to post some pics if I get a chance tonight....
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #34 of 134 Old 12-11-2011, 07:06 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
heres some pics of the water valve and vacuum acummulator tank...thing.
I highly recommend using these from a newer cherokee, the vacuum lines are more simplified and the water valve it better quality and more simplified.
The accum tank has 1 larger tube that runs right to the vacuum source, has all the check valves, and tees off for the vacuum needed for the whole AC system.
I am going to try to find time to make an AutoCAD drawing of the system.
post #35 of 134 Old 12-11-2011, 07:08 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
sorry. heres bigger pics
post #36 of 134 Old 12-11-2011, 07:09 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
man, I need to charge my digital camera, cell phone pics suck haha
post #37 of 134 Old 12-11-2011, 07:51 PM
dodger889
Hey I used the same reserve tank from the xj when I did my engine swap because I also used the Cruise Control in the YJ. It nice to have CC on the turn signal stock.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #38 of 134 Old 12-12-2011, 04:52 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
I was thinking about doing the same thing later down the road...
post #39 of 134 Old 12-12-2011, 08:18 AM
dodger889
If you are doing this with the diesel engine is going to be harder than I had. The CC is controlled by the ECM. Now if you where to install a separate controller that would be a different thing all together.
post #40 of 134 Old 12-12-2011, 08:22 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Yea, I was wondering if I could get everything from an XJ wired up and fool the ECM with the correct speed sensor...... definitely a different project haha.
post #41 of 134 Old 12-12-2011, 09:13 AM
Que89YJ
The ecu controlls the electric rad fan and will change the idle to compensate when loaded. I will be intersted to see if you get it working.
Que89YJ is offline
post #42 of 134 Old 12-12-2011, 09:59 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Well, I am not really worried about idle change, I dont think the load of the AC compressor is going to load a 4BT enough to where it is very noticable, and there is really no way to electronically control the idle on a 4BT, well, I'm sure it is possible, but no point really...
I am probably going to hardwire an additional electric fan. Not sure where I am going to put the condenser either, my intercooler is kinda in the way, So I may have to mount it elsewhere in the engine compartment with an additonal fan either way.
I do not think it will be difficult to find a signal wire to turn the fan on when the AC is on.....
post #43 of 134 Old 12-12-2011, 10:13 AM
Que89YJ
I didn't notice the 5.7! It's actually not so much the compressor as the fan. That electric fan is a huge in rush draw as much as 80 amps and continuous between 20-40 amps. The ecu was compensating for the load. In your case it's totally different. It will still load down but with as much HP as you have I don't think it matters! Like I said, if you need any help electrically I will help out. It looks like a good one to do as a writeup.
Que89YJ is offline
post #44 of 134 Old 12-12-2011, 11:02 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
The Chevy 350 5.7 was my old Jeep.
I now have a different one that I put a 4BT into. I still need to find an A/C compressor from a Dodge ram cummins for a reasonable price.
an A/C fan will really draw that much load!?!? I run a taurus electric cooling fan right now that is just thermostatically controlled, and I would think the engine cooling fan would draw a lot more.
Hmm, I wonder if it would be benficial to run some type of independent thermostatically controlled deal for the A/C, but I figured it would be best to just have the A/C fan run constantly if the A/C is turned on.
Looks like I need to do some additional research. I would obviously not just run a wire from the ac controls to the fan, I would definitely have a relay of some type in there, which is another reason I want to utilize the YJ power distribution center.
Do you think I will be ok if I just run it through a relay to be on when the A/C is on? I am a mechanical engineer, not electrical haha. I am only a novice with wiring.
I guess my biggest concern would be my alternator, and how well it would keep up on a hot day running an engine cooling fan and A/C fan, and lights, ect. Not sure of the ratings on my alternator, but I would assume it would be fairly powerful being on a 4BT....
I think a write up will be in order once I get it all figured out. I'll just try to remember to keep things documented.
post #45 of 134 Old 12-12-2011, 11:29 AM
Que89YJ
If you have a Taurus fan then it is just a matter of wiring then to make the taurus fan work for you. The controller I have has an input for the AC to drive the taurus fan mod. I am using the Hayden and it has the setup for it to override the thermocoupler when turning on the ac.
Que89YJ is offline
air flow control door in the HVAC system LiveAndLearn TJ Wrangler Technical Forum 4 10-02-2010 06:33 AM
vacuum system hoses all hooked up but system doesnt work snowcrawlr619 YJ Wrangler Technical Forum 8 12-28-2009 07:52 AM
Asking for HVAC help.... sandmangreg TJ Wrangler Technical Forum 3 08-19-2008 10:00 PM
Need HVAC help clhman TJ Wrangler Technical Forum 1 02-01-2008 04:05 PM
hvac system dosen't work?? drew76924 TJ Wrangler Technical Forum 3 10-30-2006 11:15 AM
