XJ front DS as YJ front DS; TC yoke change?? - JeepForum.com
post #1 of 22 Old 10-20-2011, 04:43 PM Thread Starter
GilNewJeeper
2008 KK Liberty
If I'm using a front XJ DS as a front YJ DS do I have to change the yoke at the TC?
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
post #2 of 22 Old 10-20-2011, 05:42 PM
YJames90
YJames90's Avatar
I see you can use 99 TJ shafts too?My friend has a 99 and its got the same double CV H joint
My 2.5 to 4.3 swap thread
YJames90 is offline
post #3 of 22 Old 10-20-2011, 10:13 PM
Apollo12227
I have XJ front driveshaft as my front driveshaft. You need the front yoke off the XJ transfercase at the same time you get the driveshaft. It will have to be lengthened to fit.
Apollo12227 is offline
post #4 of 22 Old 10-21-2011, 05:09 AM Thread Starter
GilNewJeeper
2008 KK Liberty
Thanks a lot, yes I know I have to lengthened the XJ DS. I wasn't sure about the yoke. I have another question: A 1" shackle lift will throw the length of your OEM front DS off by 6"?
2008 Jeep Liberty
post #5 of 22 Old 10-21-2011, 05:16 AM
grandboost98
ive never heard of that before. i have 1" shackles and didnt have to mess with my drive shafts
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #6 of 22 Old 10-21-2011, 08:42 AM
Apollo12227
My shackle lift definitely called for a longer driveshaft but that was only because I'm already SOA with 2" springs. I would get your jeep sitting exactly where you want it and then make a custo measurement from ujoint center to ujoint center. This way you know you are spot on in length.
Oh and FYI, the XJ yoke and YJ yoke are interchangeable, just toss up the cv-style XJ yoke and you are good!
post #7 of 22 Old 10-21-2011, 11:16 AM
manicjester3
A TJ front drive shaft will work, you just need the CV style yoke off of basically any Jeep with a CV style front output yoke. Manual 4 cyl or automatic 4 or 6 cylare the same length, and the 6cy manuals are longer. So you would need to get one from a 97-02 with a with the same setup as your Jeep. Later drive shafts, I'm not really sure about, but I did just buy one from a 05 (not sure of engine or trans) and it works perfectly for my Manual 6cyl YJ.
manicjester3 is offline
post #8 of 22 Old 10-22-2011, 05:20 PM Thread Starter
GilNewJeeper
2008 KK Liberty
That's what I thought but check the difference in size between the "black" DS and the other one. The "black" DS is the one "this" guy gave me. Supposedly this is the DS HE pulled from my Jeep. The other one is a DS from a bone yard (4Cyl manual).
They are fully closed
2008 Jeep Liberty
post #9 of 22 Old 10-22-2011, 05:36 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Not to hijack but what is the difference in ujoint size? I'm looking to do this, I need spares!
Luck Favours The Prepared
Anticanman is offline
post #10 of 22 Old 10-22-2011, 05:39 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Can you get some actual measurements? Both driveshafts and actual length between yokes?
post #11 of 22 Old 10-22-2011, 05:47 PM
94chb
so your comparing a 2.5l front drive shaft to a 4.0l front drive shaft of coarse they are going to be different lengths
94chb is offline
post #12 of 22 Old 10-22-2011, 06:57 PM Thread Starter
GilNewJeeper
2008 KK Liberty
Hey I'm comparing nothing, my rig is a 94 Sahara 4.0 I6cyl. I took the Jeep to "this mechanic" to re-gear the front axle and replace the rear but HE dropped the job half way. He disconnected the front DS because of the ratio difference (front 3.73: rear 3.07) so he gave me the "black DS" when HE abandoned the job and I left. Now I'm putting the rear on the Jeep 3.73 but when the mechanic try to fit the DS it was @ 6" short, that's my point here. This "JERK" (Solofabworks.com) gave the wrong DS obviously. If you read carefully you can see that I got the DS from a bone yard and we fit/test it and is the correct length
2008 Jeep Liberty
post #13 of 22 Old 10-22-2011, 07:00 PM Thread Starter
GilNewJeeper
2008 KK Liberty
The long DS is @ 40" long, the black is short @ 36" and I don't know from which vehicle HE took it.
2008 Jeep Liberty
post #14 of 22 Old 10-22-2011, 08:28 PM
Hghgrad
I just swapped mY wrangler from a 4cyl auto to a 4.0 manual. The measurement I took from yoke to yoke was about 40 3/4". Fully extended, my 2.5 auto shaft was 41". I didn't take a measurement of the new front shaft, but it was substantially longer.
So, if it was swapped to a manual, it would explain the different shafts.
I just read a little more carefully and see that you got it figured out.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #15 of 22 Old 10-23-2011, 07:18 AM Thread Starter
GilNewJeeper
2008 KK Liberty
This is the measurement @ 40 3/4" of my rig (yoke to yoke). This is about right.
2008 Jeep Liberty
hack and tap yoke??? th350 yoke or front t-case output yoke on rear?? 02wrangler_guy TJ Wrangler Technical Forum 5 02-15-2016 03:09 PM
how to... t/c front output shaft and front axle yoke nut removal? shinigami YJ Wrangler Technical Forum 2 05-22-2010 08:14 AM
XJ NP231 Front Yoke Douglas S. YJ Wrangler Technical Forum 1 12-01-2009 09:34 AM
Front Driveshaft/Yoke Bhelliom TJ Wrangler Technical Forum 13 08-16-2007 06:50 AM
NP-231 Front Yoke Needed YJ-Mike YJ Wrangler Technical Forum 0 02-04-2007 06:18 AM
