xj front driveshaft into a 95 yj auto trans - JeepForum.com
post #1 of 4 Old 09-17-2011, 07:53 AM Thread Starter
extremepsi
what years do i look for to convert the front xj driveshaft
extremepsi is offline
post #2 of 4 Old 09-17-2011, 09:05 AM
moonshinefuel
For purposes of an sye install, the 91-95 years have been confirmed to work well. Others may work. You will need to have it cut down to fit.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 4 Old 09-17-2011, 09:13 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Mine came from a 99 Cherokee.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #4 of 4 Old 09-17-2011, 09:22 AM
mike_breaker_5
i HAD a front shaft from a 93 zj (as far as i know same joints just different length as xj). but i exploded it doing burnouts on dry pavement on 31"s in 2wd. oops, now i have a temporary front wheel drive yj. off the top of my head i think the measurement for the rear DS length at ride height is somewhere around 16"-17" range on stock suspension with a sye.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 09:30 AM
will a stick frt driveshaft work in auto trans? TJSilverSport02 TJ Wrangler Technical Forum 3 05-24-2006 03:29 PM
front driveshaft/auto tranny skid prob Texas TJ TJ Wrangler Technical Forum 6 04-22-2006 07:47 PM
Tj auto front driveshaft - same as 5 speed one? skyjacked94xj TJ Wrangler Technical Forum 1 12-11-2005 09:40 AM
Front driveshaft hitting trans skid plate Randall Flagg TJ Wrangler Technical Forum 3 08-06-2005 06:48 PM
