xj front drive shaft for yj rear - JeepForum.com
post #1 of 2 Old 01-25-2009, 10:28 PM Thread Starter
teejmcd
so i may resize an drive shaft for my yj sye. i got an 8.8 with a 1330 joint adapter, do all xj drive shafts have 1310 joints and what joint is on the t case joint, 1310?
1994 yj. lifted 4 inches locked, loaded, and armored!
Member of CORE4X4.NET
teejmcd is offline
post #2 of 2 Old 01-26-2009, 04:30 PM
Cobra Jeep
Yes, all three u-joints on the XJ shaft are 1310.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
What size wrench will I need to remove Front and rear drive shaft? Jeepsr4me19 YJ Wrangler Technical Forum 3 08-28-2009 04:57 PM
Front Drive Shaft - Ball Kit in between CV at REAR (double universal joint) czar97 TJ Wrangler Technical Forum 5 12-15-2008 07:15 AM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
swapping front drive shaft to rear Texas TJ TJ Wrangler Technical Forum 8 11-14-2005 12:23 PM
Front Drive Shaft For The Rear 86comanche TJ Wrangler Technical Forum 1 07-06-2005 10:43 AM
