XJ driveshaft - JeepForum.com
post #1 of 8 Old 04-18-2010, 06:11 PM Thread Starter
highrolrcustoms
XJ driveshaft
i tried searching but couldnt find the answer to my question....i see that everyone takes the xj front driveshaft and has it cut down for the rear driveshaft....will the xj driveshaft work on the front on a yj?? i need a cv on the front driveshaft due to angle.
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline
post #2 of 8 Old 04-18-2010, 06:16 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I have shortened several, and have another I'm doing now.
If the YJ NP231 has the correct front yoke - yes (other than the length may not be correct). Key here is that front yoke, plus length.
Joe Dillard is offline
post #3 of 8 Old 04-18-2010, 06:18 PM Thread Starter
highrolrcustoms
do the yokes interchange? if so when i pick up the driveshaft i will get the yoke also
post #4 of 8 Old 04-18-2010, 06:22 PM
Joe Dillard
Lemme check......
post #5 of 8 Old 04-18-2010, 06:42 PM
Joe Dillard
I'm finding some conflicting data, which could be due to ujoint size (not necessarily due to 231/242.
EG: This http://www.4wd.com/productdetails.as...5&partID=44923
http://www.4wd.com/productdetails.as...5&partID=11421
post #6 of 8 Old 04-18-2010, 06:57 PM
modfox
Can you put a XJ transfercase in a wrangler if you use the yokes?
I see XJ transfercases for about $75 and YJs for $400....
90 YJ 4 cyl 5 speed
65 Ford Mustang 289/c4
2010 Kia Soul
modfox is offline
post #7 of 8 Old 04-18-2010, 06:58 PM
Alfons
The connecting yoke between the CV and the t-case or diff (if you have a 2 CV shaft) is different from the standard single cardan yoke, it's deeper and you'll need longer bolts to hold it to the joint - this only applies to the XJ shaft with the double cardan joint.
Here's a picture of 2 modified XJ shafts, one for the front and one for the rear, the new yoke you see at the top is the CV yoke that will fit a YJ. The XJ CV yoke won't fit the YJ t-case:
Alfons is offline
post #8 of 8 Old 04-18-2010, 09:23 PM
Apollo12227
Yes a Cherokee tcase swaps right over, the older tcases have a different spline count on the front output shaft so that is something to check before purchasing...
The Cherokee front output yoke can be swapped over to the YJ... It's literally a matter of pulling the nut off the yoke, pulling the yj yoke off, re-use the little rubber seal, slip the xj yoke on, and put the nut back on.
I have an xj driveshaft in the front of my jeep, all you need is the driveshaft, xj yoke, and bolts, nothing more. You will have to have the front driveshaft LENGTHENED but that's it.
In the rear you will need a SYE, there is no slipyoke that just swaps over to accept a CV shaft to my knowledge so of u have a SYE then the rear shaft will bolt on as well.
Apollo12227 is offline
DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ Joe Dillard YJ Wrangler Technical Forum 43 08-12-2014 07:53 PM
SYE and CV driveshaft tweetermx14 TJ Wrangler Technical Forum 9 05-15-2009 10:48 PM
Driveshaft..... dali555 TJ Wrangler Technical Forum 5 03-21-2007 05:25 PM
yj driveshaft on tj? AFrecords00 TJ Wrangler Technical Forum 1 04-10-2006 09:29 AM
do i need a new driveshaft? RnEmOvr TJ Wrangler Technical Forum 2 01-07-2006 11:59 AM
