xcase locked up? - Page 2 - JeepForum.com
post #16 of 28 Old 05-29-2013, 11:24 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by Lemoore-on View Post
Pull it & crack it open to see whats wrong.
Why does it take so long to get the correct answer? Bravo lemoore-on.
Luck Favours The Prepared
Anticanman is offline
post #17 of 28 Old 05-29-2013, 12:28 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Two people said that before him.
Michaelgoesrawr is offline
post #18 of 28 Old 05-29-2013, 12:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
My apologies Michael, I just kinda skimmed the last couple posts and ended up there. But still shouldn't have taken that long for a diagnosis.
post #19 of 28 Old 05-30-2013, 02:14 PM Thread Starter
Cocopebels
Well, come to find out, it isn't the transfer case and is indeed the front end. I pulled the front cover and to no surprise comes muddy thin water with very little gear oil. Locked the 4wd in wile motor running killed the motor put it in neutral crawled in front of the jeep rocked it back and forth and watched bind up and pop. I'll try and get a video of it.
Cocopebels is offline
post #20 of 28 Old 05-30-2013, 02:16 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
So it didn't bind up with the driveshaft off.
post #21 of 28 Old 05-30-2013, 03:41 PM Thread Starter
Cocopebels
It is binding when I lock the front end. The ring or pinion don't want to turn both side gears and spider gears turn? Every thing turns just fine except the ring and pinion. That's all I know about it. Never have tore in to differentials before
post #22 of 28 Old 05-30-2013, 03:47 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Open up the cover and take a looksee. Pictures will help us diagnose it.
post #23 of 28 Old 05-30-2013, 03:58 PM Thread Starter
Cocopebels
You can tell by the rust on the ring and pinion teeth that it hasn't been turning.
post #24 of 28 Old 05-30-2013, 04:00 PM Thread Starter
Cocopebels
They turn mabey 10-15 degrees before locking up.
post #25 of 28 Old 05-30-2013, 04:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Is that with the vehicle on the ground or the front axle in the air?
post #26 of 28 Old 05-30-2013, 04:22 PM
imstillatwork
Originally Posted by Cocopebels View Post
Front drive shaft isn't in. And i don't think its the front end neither cause I unplugged the actuator? That locks it in and it still pops. It will move ~2 ft before it binds up then pops and will go another 2 ft.
This part. Front drive shaft isn't in. Front drive shaft actually is in? Changes everything.
imstillatwork is offline
post #27 of 28 Old 05-30-2013, 04:47 PM Thread Starter
Cocopebels
There is no front drive shaft in. Its laying in my garage in two pieces. Its the front end that's locking and popping. It only does it when the two front tires are locked together. IIvtaken the actuator off and used my fingers to lock and unlock it. So I know its only when both wheels are locked together.
post #28 of 28 Old 05-31-2013, 08:00 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Your bearings are beyond shot. Time to start over with another axle.
