write up for electric fan install - JeepForum.com
post #1 of 4 Old 06-06-2006, 08:57 PM Thread Starter
sandman'sjeep
I'm looking for a write-up on installing an electric fan for my 87 I6... changed everything you possibly can on the cooling system except doing a compression test (which will be done this weekend). For some reason it still overheats (goes to 220) ... any help would be great guys...
sandman'sjeep is offline
post #2 of 4 Old 06-06-2006, 11:24 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
electric fan won't help you if your current fan is working properly. in fact, it could hurt you
what have you replaced in your cooling system thus far?
-Erik <---- will help with wiring online, but i don't think thats going to solve your problems
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 4 Old 06-07-2006, 10:06 AM
Taco88yj
i run at 210 here it sucks. im thinking about adding cutting a hole in my hood and installing a mini radiator up there and just adding more plumbing and a small electric fan on it.
the main problems with my YJs cooling is the lack of a heater core. ( one less place for water to go and displace the heat )
Taco88yj is offline
post #4 of 4 Old 06-07-2006, 12:02 PM
Slapahoe
Registered Jerk
Slapahoe's Avatar
I had an issue with cooling and then I just replaced the clutch fan and it solved the roblem. perhaps you should try that.
I am in the process of finding someone who will louver my hood so I can fab up a flex-a-lite fan to the top to push hot air out. maybe that will work.
93 YJ 4.0HO
'03 KJ Renegade
Slapahoe is offline
Electric Fan Install Write up (Taurus, Mark VII) Mr.B YJ Wrangler Technical Forum 164 08-02-2016 11:05 AM
4.0 TJ Header Install Write-up?? chilijeep TJ Wrangler Technical Forum 8 01-01-2015 10:58 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 08:59 PM
Good Write UP for RE 4.5 install? BigPeters TJ Wrangler Technical Forum 3 01-25-2006 04:33 PM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 11:10 PM
