Write up on Coolant Flush? - JeepForum.com
post #1 of 4 Old 05-15-2010, 11:58 PM Thread Starter
Dhofstet
1973 KK Liberty
I need to do a radiator/coolant flush and i am having trouble finding write ups. Does anyone have one?
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline
post #2 of 4 Old 05-16-2010, 04:38 AM
InEmberClad
They have kits at your autoparts store, theyre like 14 dollars. You just plug in a T connector, then to that a garden hose, turn on your heater and run the water. The junk will flow out of a funnel you plug in to the radiator. Super easy, acceptably effective.
Not a bad idea to replace your t stat and water pump gaskets next depending on how long its been since your coolant system has gotten attention... unless you dont have any leaks... which would mean either you just did this anyway or you jeep is made of magic.
InEmberClad is offline
post #3 of 4 Old 05-16-2010, 12:57 PM Thread Starter
Dhofstet
1973 KK Liberty
I was just looking at my maintenance schedule and it said i should be doing a Coolant Flush around this time. I have never done one before..
Dhofstet is offline
post #4 of 4 Old 05-16-2010, 01:17 PM
Axl Jack
Bought my 94 in 2000. Have never touched the t-stat or water pump or their respective gaskets ever. No leaks. Mine must be magic then.
I do flush my system every 2 years though.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
Flush Mount Factory Tail Lights - YJ - Write-Up jesseleikerjeep YJ Wrangler Technical Forum 35 01-24-2010 11:52 AM
heater core flush, write up?? jakecarder TJ Wrangler Technical Forum 2 01-09-2009 07:50 PM
4.0l coolant flush valacech TJ Wrangler Technical Forum 10 05-10-2008 09:03 AM
PSC Trail Corners and Flush Mount Lights Write Up REDLYNER TJ Wrangler Technical Forum 2 02-08-2007 10:46 AM
coolant flush dazed TJ Wrangler Technical Forum 2 12-14-2005 01:22 PM
