I'm going to change the diff fluid in my YJ for the first time since I bought it last fall. It has the stock axles (Dana 30 in the front I think?) The drain plug for the diff has a hex plug in it that is bigger than my biggest hex wrench.
Any one know off hand what size that bugger is?
The rear diff seems to have a rubber plug of some sort. I assume that just pulls out?
got a pic? i can't imagine the diff having a plug in it that large, unless your wrenches don't go past about 5/8". my front has a 9/16" square plug. the t-case has large drain and fill plugs near where the drive shaft goes into it in the rear which are 30 mm. are you talking about those?
OK you guys are exactly right. Note to self -- look closer before opening mouth. As you all said, there's only one plug in each diff cover and the front at least is a square drive, not a hex.
So I'll be removing the covers to drain. Do they use a gasket when I button them back up? Or do you use RTV on them?
I was just on spring break and did the same thing myself. I have stock D35 rear and D30 front. I have filler plugs, but to drain you have to remove the diff cover.
Be careful to keep that CLEAN.
In the quadratec catelog you can't get the gasket unless you buy the whole differential rebuild kit for $99..... so just go to any auto parts store and get the gasket for a buck.
My Haynes manual suggests pumping out the fluid as an alternative -- which might not be such a bad idea if the fluid you are replacing is just old (as opposed to contaminated or dirty). No worry about resealing the gasket.
They make a small hand pump especially for that purpose.
agree 100%
preventative maintenance is always cheaper than fixing after a blow up....
will cost you @15 minutes and a $4 tube of permatex rtv.
cheap insurance.
martin
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
