Wrangler YJ 4.0 Wiring harness - JeepForum.com
post #1 of 3 Old 01-09-2011, 08:04 AM Thread Starter
Kenzo
Hello,
I have placed a AMC 242 (4.0L HO 6 cylinder) from a 1993 Cherokee XJ into my 1993 Wrangler YJ wich was a 2.5L 4 cylinder.
Now i have to find a wiring harness.
I have been told a complete Wrangler YJ 4.0L wiring harness would fit completely.
In holland it's hard to find so i looked on American Ebay.
I found one harness but i don't know if this will fit and work.
http://cgi.ebay.com/Jeep-YJ-4-0-wiri...#ht_2108wt_905
Could somebody please tell me if this will fit to a:
1993 Wrangler YJ (which was a 2.5L)
1993 Cherokee XJ Engine with AX-15 Manual transmission & NP-231 Transfer case?
It says it was combined with an automatic transmission so will this fit to an AX-15 with NP-231?
I appreciate it if i get an answer soon because the auction ends soon!
Thank you very much!
Kenzo
Kenzo is offline
post #2 of 3 Old 01-09-2011, 11:16 AM
Alfons
Originally Posted by Kenzo View Post
Hello,
http://cgi.ebay.com/Jeep-YJ-4-0-wiring-harness-ECM-Wrangler-wire-motor-/180606906815?pt=LH_DefaultDomain_0&hash=item2a0d02 b1bf#ht_2108wt_905
Kenzo
That harness is from a 91, but it will work in your jeep and with that engine. You will run into a few connector issues in the cabin section of the harness but you can either use your own cabin harness or splice in the connectors that are different (these will be around the instrument panel and the "tell-tale" lights). I didn't take a real close look at the ebay pictures, so I didn't notice if it had the manual or automatic transmission connector - the manual transmission connector has a jumper built in to bypass the start-up safety switch.
With a wiring diagram, this should be fairly easy to install and make work on your jeep.
Alfons is offline
post #3 of 3 Old 06-10-2016, 09:22 PM
reamettejohnson
I have a 92 jeep wrangler 4cyl 2.5 I want to know if a 91 wrangler wiring harness will fit my jeep
reamettejohnson is offline
wrangler wiring harness kukuni17 YJ Wrangler Technical Forum 14 06-25-2016 12:54 PM
92 Wrangler wiring harness nickaldrich YJ Wrangler Technical Forum 7 10-23-2014 03:40 PM
Do I need a wrangler specific 4.0 wiring harness? gsmith795 YJ Wrangler Technical Forum 19 03-25-2009 06:26 PM
Question about the '02 hardtop to '03 Wrangler wiring harness US1 TJ Wrangler Technical Forum 0 12-01-2008 07:50 AM
1994 Wrangler Wiring Harness iowajeepers YJ Wrangler Technical Forum 6 06-13-2008 09:12 PM
