wrangler wiring harness - JeepForum.com
post #1 of 15 Old 03-17-2010, 06:42 AM Thread Starter
kukuni17
1971 CJ5
Is a 1992 wrangler under dash wiring harness exchangable for a 1991 wrangler under dash wiring harness. I know that jeep revamped the gauges in 1992.
kukuni17 is offline
post #2 of 15 Old 03-17-2010, 06:46 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
There shouldn't be too many changes under the dash but '92 was the "bastard year" for the YJ. Alot of things only work for the '92.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 15 Old 03-17-2010, 09:57 AM
CjinPA
CjinPA's Avatar
No, a 92 under dash harness will not work in a 91. The 92 harness is completely different than the 91. 1991 was the crossover year, first year for the 4.0L motor in the YJ. An 87 to 91 under dash harness will work in your 91 YJ.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #4 of 15 Old 03-17-2010, 07:47 PM Thread Starter
kukuni17
1971 CJ5
Thank you......
kukuni17 is offline
post #5 of 15 Old 04-05-2010, 03:41 PM
ccloyd
91 YJ Wiring Harness Interchangeability
Can anyone tell me if a 1991 engine wiring harness is the only one that will work on my 91 wrangler? Will a 92? 88? etc...
ccloyd is offline
post #6 of 15 Old 04-05-2010, 04:04 PM
idaholtby
As far as the engine harness' from 91-95 go, they are the same and are interchangeable. The only differences will be that some of the sensor connections changed between the years, but this is easily remedied. For instance, the '91 engine temp sensor for the gauge had a single wire push on connection, were as the '92 and later had a weather pak connector. Same is true for the oil pressure sensor, but the electrics is the same, only some of the connectors for the sensors may be different. If I missed something, I am sure it is easily overcome. The OBDI engine harness is essentially the same and is compatible from '91-'95 except for the few sensor connections that are easily overcome. Pre '91 is a different ball game altogether.
idaholtby is offline
post #7 of 15 Old 04-05-2010, 04:07 PM
ccloyd
Thanks for the info. I'm only missing one section of the harness - the section from the firewall to the speed sensor on the tranny, so I suppose I better stick with a 91...
ccloyd is offline
post #8 of 15 Old 04-05-2010, 04:31 PM
idaholtby
Good choice, the speedo drive for the '91 (outside of the engine bay wiring) is different from all other years. The '91 uses both a mechanical and VSS output sensor at the transfer case outlet. On the '91 this is a two wire output and has a reed actuated switch for the VSS and still has the mechanical cable drive for the speedometer. '92 and later does not have the mechanical cable output and supplies the speedometer and VSS info with a hall effect sensor to the ecm.
post #9 of 15 Old 10-05-2015, 03:28 PM
Long54
Newbie
ok so what about the 2.5l? what wire harness will match up to a 91 2.5l since it is fuel injected?
Long54 is offline
post #10 of 15 Old 10-06-2015, 06:58 AM
Que89YJ
Long this is a old thread. You really should fill out your profile and post up to a new thread. As far as matching up it depends on what you are doing and with what section of the harness. Post up with the vehicle info to a new thread and you can get more help.
Que89YJ is online now
post #11 of 15 Old 06-24-2016, 11:45 PM
CherryYJ
Ok so if I have a 1989 2.5L original harness under the dash and a 1994 yj 4.0MFI w/ the harness. How do I make the 89 dash harness work with the 1994 YJ Engine harness. Come on guys/gals help me out. Please don't say it's impossible. Lol
CherryYJ is offline
post #12 of 15 Old 06-25-2016, 04:15 AM
Que89YJ
It's not. 5 to fire. You need to do the swap at the bulk head connector and the one in the middle. Do you have the manual for the 89 & 94? Do you have a meter and know how up use it?
Fault codes:
Mean Max pics of everything:
No Start:
post #13 of 15 Old 06-25-2016, 06:04 AM
CherryYJ
I belive I have a Chilton manual.. also have a volt meter.
CherryYJ is offline
post #14 of 15 Old 06-25-2016, 08:36 AM
Que89YJ
I'm not going to have time to dedicate to you this weekend. I am going to get you started though
First use google search this way to search the forum for info:
http://www.jeepforum.com/forum/f12/f...oogle-1003734/
Go to this thread on post 11 and download the factory service manuals.
http://www.jeepforum.com/forum/f12/1...start-1414928/
I have a copy of the 95 but cant get it to you until Monday. Look up 5 to fire and see if you can find some of the info using the search trick I posted.
post #15 of 15 Old 06-25-2016, 12:54 PM
Jeepsr4me
It can be done.... BUT you will be pulling some wires out of the bulk head connection and putting them in another slot.
Its not bad.. But do a search online for 87 bulkhead connector pin out.. then the 94.... There is a couple good
http://www.jeepforum.com/forum/f12/4...-list-1004732/
Jeepsr4me is offline
Do I need a wrangler specific 4.0 wiring harness? gsmith795 YJ Wrangler Technical Forum 19 03-25-2009 06:26 PM
Question about the '02 hardtop to '03 Wrangler wiring harness US1 TJ Wrangler Technical Forum 0 12-01-2008 07:50 AM
1994 Wrangler Wiring Harness iowajeepers YJ Wrangler Technical Forum 6 06-13-2008 09:12 PM
Wrangler Engine Wiring Harness 4.0 L 2003 robbytwo1 YJ Wrangler Technical Forum 5 06-06-2008 06:51 PM
2007 Wrangler Unlimited 4DR - Dash Kit & Wiring Harness Available? BIGKernel44 JK Wrangler Technical Forum 2 06-06-2007 11:36 AM
