Wrangler Soundbar Fitment - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Wrangler Soundbar Fitment
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 10-07-2008, 01:04 PM   #1
dbdragracing
I have a 1992 Jeep Wrangler and Im looking to get a soundbar...I located a used soundbar out of a 1998 Wrangler...will it fit in mine? Thanks.
dbdragracing is offline   Reply With Quote
Unread 10-07-2008, 01:24 PM   #2
sam.b.
yes it will
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
www.kifourwheelers.com << Louisville Ky. based 4x4 club
sam.b. is offline   Reply With Quote
Unread 10-07-2008, 01:27 PM   #3
dbdragracing
Thanks for the help!
Unread 10-07-2008, 02:04 PM   #4
Tompatt
1987 YJ Wrangler
srry for the highjack. but isnt that a tj? a tj sound bar would fit in a yj?
Thomas
-1987 YJ
Jeep Build
Tompatt is offline   Reply With Quote
Unread 10-07-2008, 02:38 PM   #5
dbdragracing
Does anyone know for sure before I buy this soundbar...a TJ soundbar will work in a YJ? Thanks.
Unread 10-07-2008, 02:51 PM   #6
usmcestep
I don't see why not. If you are wanting a soundbar though, PM me I have the 6 speaker VDP soundbar that I got off of quadratec last year. If you want to work out a deal let me know...
05 TJ RME 4.0
3" Zone 2" BL
35x12.50 procomp xterrains
Rear smittybilt bumper with swingout tire carrier
www.tnmudders.com
usmcestep is offline   Reply With Quote
Unread 10-07-2008, 03:07 PM   #7
sam.b.
like i said before it WILL work << experience talking here
only thing you will need to do is splice some wires together correctly left and right wise and for the dome light(best part IMO)
you will also need to bolt it down some how, i used large zipties and its held up well but ive never rolled or flopped so i dont know how it will hold up in either
98 TJ Mild DD
90 YJ Sold
Unread 10-07-2008, 03:39 PM   #8
sebastian22
Im pretty sure it would work, BUT it would have to mount in front of the roll cage center hoop, instead of behind it, as it does in the TJ's.
[B]95 Black YJ[/B] [URL="http://www.jeepforum.com/forum/f22/sebastians-yj-build-wheeling-thread-842068/"]*Build Thread*[/URL]
2.5L, [URL="http://smg.photobucket.com/albums/v63/sebastian22/Rubicon%20Express%20Lift/"]4.5" RE springs[/URL], [URL="http://jeepforum.com/forum/showthread.php?t=623000"]MORE hoops[/URL] [URL="http://jeepforum.com/forum/showpost.php?p=4672334&postcount=11"]1" BL[/URL], 35" KM2's, [URL="http://www.jeepforum.com/forum/f37/tube-fenders-940426/"]Tube Fenders,[/URL] [URL="http://www.jeepforum.com/forum/showpost.php?p=5397585&postcount=270"] Full Cage[/URL], [URL="http://www.jeepforum.com/forum/showpost.php?p=5314968&postcount=8107"]D30 Aussie[/URL], [URL="http://www.jeepforum.com/forum/f12/dana-30-tj-axle-shaft-conversion-seal-replacement-1324963/#post12996405"]D30 TJ shafts[/URL], [URL="http://jeepforum.com/forum/showthread.php?t=214660&page=811"]TeraLow 4:1[/URL], [URL="http://jeepforum.com/forum/showthread.php?t=522011"]HF 8K Winch[/URL] [URL="http://jeepforum.com/forum/showthread.php?t=15446&page=3"]Herculiner[/URL], [URL="http://img.photobucket.com/albums/v63/sebastian22/Warn%20Steering%20Skid/IMG_2591.jpg"]Warn steering[/URL] & [URL="http://jeepforum.com/forum/showpost.php?p=5351310&postcount=2640"]Gas Tank skids[/URL], [URL="http://jeepforum.com/forum/showthread.php?t=597744"]LED tail lights[/URL], [URL="http://jeepforum.com/forum/showthread.php?t=597744&page=2"]TJ corners[/URL], [URL="http://www.jeepforum.com/forum/showthread.php?t=610047"]Rock Sliders[/URL], [URL="http://jeepforum.com/forum/showthread.php?t=636291"]Ford 8.8[/URL], [URL="http://www.jeepforum.com/forum/f22/sebastians-yj-build-wheeling-thread-842068/index3.html#post8235343"]JCR OTK Steering[/URL], 4.88 gears
sebastian22 is offline   Reply With Quote
Unread 10-07-2008, 03:44 PM   #9
jaminb
you also have to watch out if you have new or aftermarket seats, i bought some VDP sound wedges, and because my seats sat up higher my head would hit the speakers on bumps and such.
jaminb is offline   Reply With Quote
Unread 10-07-2008, 04:37 PM   #10
Tompatt
1987 YJ Wrangler
thats ok. i got the sport style roll bar anyways.
Thomas
-1987 YJ
Jeep Build
Unread 10-07-2008, 05:35 PM   #11
usmcestep
mine fits the sports style as well as the family style
05 TJ RME 4.0
3" Zone 2" BL
www.tnmudders.com
Unread 10-07-2008, 07:08 PM   #12
sebastian22
I could be wrong here, but I'm fairly sure that the TJ soundbar is designed to fit tightly just behind the main hoop on the cage.
One thing I AM sure of is that the rear half of the TJ factory cage is different than that of the YJ. The rear bars on the YJ "family style" cage come in at an angle towards the inside, making the distance between the two rear bars narrower.
So because of that I would be willing to bet that the TJ soundbar would be too wide to fit behind the main hoop on the YJ "family style" cage. However it should fit just fine in front of the main hoop.
Unread 10-07-2008, 07:43 PM   #13
sam.b.
this is true but if you have a sport bar still then you really dont have much of a choice unless you can mount it on the downward bars
i may try that while im building my cage just for some laughs, maybe ill just leave it out or i may build the rear halo so that i can still fit hte sound bar
98 TJ Mild DD
90 YJ Sold
Unread 10-07-2008, 08:31 PM   #14
Lumpymayo
Here, take a look at this.
http://jeepforum.com/forum/showthread.php?t=553768
Lumpymayo is offline   Reply With Quote
