Wrangler Rust - JeepForum.com
post #1 of 3 Old 07-16-2008, 05:32 PM Thread Starter
Justin1805
1994 XJ Cherokee
Wrangler Rust
I was thinking trading a car of mine for a wrangler, but the guy said it had a rusted frame very bad, i was seeing if it is safe to drive a wrangler with a rusted frame.
Justin1805 is offline
post #2 of 3 Old 07-16-2008, 05:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
If everything else (driveline, body, interior, etc.) is okay, and it's cheap enough, get it & find a donor frame.
If it's really all that bad, I wouldn't drive it that way though.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 3 Old 07-16-2008, 05:47 PM
NJeepyj91
There is lots of great advice on this forum. For example, a screw driver is your friend when purchasing a YJ. Poke around on the frame with the screw driver. Is it surface rust? They all get that. Is it RUST-RUST? You want to ascertain is the frame intact. Special areas requiring special attention: Around the front horns and steering box. The long rails from the rear spring mount to the fenderwell. The rear of the jeep around the gas tank. The rear bumper mount area. Poke em, prod em, then make a decision.
Rub the hx of this vehicle. Was it a northern salt area jeep? If the frame is toast, EL PASO.\
In well due respect to Mean Max. A body off can easily be done, if YOU have the skills. If you have to pay for it, pass on this jeep.
She's going to bury me in this thing.
91 4.0 stick. Posi Lok, Borla, 31s on steelies, Dem Bonz Shackles and lots of other junk on my junk.
NJeepyj91 is offline
2009 Wrangler with alot of rust? mkck JK Wrangler Technical Forum 4 07-05-2009 11:11 PM
1994 Wrangler Frame Rust 1994Wrangler8) YJ Wrangler Technical Forum 2 01-20-2008 03:15 PM
rust spots on new wrangler 06WhiteRubi TJ Wrangler Technical Forum 8 08-03-2006 09:13 PM
1988 wrangler 4 banger RUST? CosmicCreeper YJ Wrangler Technical Forum 4 12-21-2004 02:20 PM
Rust spots - 92 Wrangler - What to do? Nitin YJ Wrangler Technical Forum 10 07-10-2001 03:14 PM
