Wrangler milage/power - Page 2 - JeepForum.com
post #16 of 53 Old 04-01-2013, 12:29 PM Thread Starter
flea1987
Originally Posted by Siva283 View Post
Going to MPFI gives you about 30 more horsepower. Not just 3. Que89yj is getting ready to do it. I just sent him the parts from my old engine. He wouldnt do it just for 3 horsepower. Also with MPFI and 33x12.5 tires I am still getting about 17mpg on stock gears.
Ok, that's what I'll look into then, because if it'll run 33's with decent mileage I could keep my wife off my back about fuel economy and throw some 31's on her
flea1987 is offline
post #17 of 53 Old 04-01-2013, 04:54 PM
Xpress
For a 4 cylinder?
Sorry, no, hate to burst your bubble but there's just no way you're going to get 30hp going from TBI to MPFI, otherwise everyone would be swapping to MPFI in the first place. The difference in HP output between the TBI and MPFI 2.5L engines is negligible.
http://en.wikipedia.org/wiki/AMC_straight-4_engine
http://www.jeepforum.com/forum/f12/y...-specs-563403/
http://www.allpar.com/mopar/amc-25.html
http://www.ehow.com/facts_7403148_je...fications.html
etc etc
The difference between the 2 different injection methods is maybe 10hp if you wind them out, otherwise the actual HP outputs in the RPM range the 2.5L engine is normally driven (between 2500 and 3500rpm) is between 3-5hp difference, not the 30 you claim it to be. As much as I hate to say it, but Que is wasting his time and money if he is expecting a 30hp gain just going to MPFI. This isn't a 4.2, it's already a pretty open flowing engine as is, that's why you can't get more HP out of it from bolting on a cold air intake, or an exhaust system. MPFI just adds in a bit of fuel efficiency (1-2mpg on a good day) and easier cold starts.
All about that unibody life.
Xpress is offline
post #18 of 53 Old 04-02-2013, 06:56 AM
Siva283
Originally Posted by Xpress View Post
For a 4 cylinder?
etc etc
I think you should go on a fact finding mission Mr. Self proclaimed Genuis. Its kinda like when you told that guy that our cooling systems have thermostats because they are so over engineered. Also since the wiring has to be redone and a new computer added unless you enjoy this type of thing even 30 horspower might not be worth it since for a little more work you could jump to the 4.0. With MPFI you get better fuel atomization and the cylinders tend to get the same amount of air fuel where this can vary widly in TBI. The power difference is very very noticable. 3 horsepower not so noticable.
Ask me how I know...
Siva283 is offline
post #19 of 53 Old 04-02-2013, 07:08 AM
Siva283
According to your allpar link. The one from the manufacturer its at a 7 horsepower difference at 5000 and 5250 respectfully. I would much prefer a dyno sheet though as even numbers from the manufacturer are not always accurate. You can really feel the difference so I am inclined to believe the guy that works for Chrystler that has told me this over you.
Siva283 is offline
post #20 of 53 Old 04-02-2013, 11:18 AM
Xpress
You really in all honestly think the MPFI setup gives you 30hp over the TBI? Good luck with getting people to believe that one. You did not read what I wrote, you skimmed over it, hell bent on trying to get your point across:
Where we drive our 2.5L engines (lets be honest, who in their right mind winds a 2.5L out to 5200rpm? Nobody does, it doesn't make any more torque over 3200rpm), in the 2500-3500rpm range, the HP difference between the 2 engines is ~3-5hp, depending on the condition of your system. If the 2.5L MPFI was putting out 160hp there would be a LOT more people going to the 2.5L MPFI setup.
So why aren't people converting to 2.5L MPFI setups?
I'll save you the time.
It doesn't give you 30hp over TBI.
If you did your research, like I did, you would see that. But since you refuse to do it, and now you're looking like a fool, you're just going to sit there and try to get your invalidated point across.
Right from 4BangerJeep:
1984- 02 2.5L AMC
Applications: 1984- 88 CJ- 7, 1984- 00 XJ, 1987- 95 YJ, 1997- 03 TJ
Displacement: 151 cubic inches
Power Output: 105-125 hp (at) 4,000- 5,400 rpm
Torque Output: 125-150 lb- ft (at) 2,600- 3,200 rpm
Bore and Stroke: 3.88 x 3.19 inches
Compression Ratio: 9.2:1
Comments: 1984- 86 engines used a single-carburator (CJ-7 only).
1984- 90, TBI was available. Then in 1991, Multi-point Fuel Injection was introduced.
XJ's always had slightly higher performance numbers then the YJ.
1997, Jeep went with a different cam profile and new ECM.
This dropped the performance numbers but gave it a flat powerband.
Mopar Perfromance made many parts for the XJ and YJ, most can be used with later engines.
Since the last parts were made 10 years ago, there are no new ones to be had.
Many of the camshafts were dumped onto the eBay.com a few years ago.
Again, the power output between the 2 injection methods is negligible.
What we can summarize from all of this info is that:
TBI Gives you between 117-125hp at 5200rpm.
MPFI gives you 120-132hp at 5200rpm.
Not the 30hp difference you claim. The modern 2.4L I4 gives you around 150hp, but it is designed a lot better and more efficiently than the 2.5L.
Xpress is offline
post #21 of 53 Old 04-02-2013, 11:26 AM
Siva283
I wind mine out when I am hung up in mud. I bet alot of others do also. I read the allpar one. The others are prone to to much error. I can easily see a 300 horsepower difference being possible. Plus like I said a will take a chrysler engineers word over yours anyday. Anyone that self proclaims they are a genus is not a reliable person in my experience. I also remember why I ignored you before. I guess I will place you back there.
Siva283 is offline
post #22 of 53 Old 04-02-2013, 11:28 AM
Siva283
1984- 02 2.5L AMC
Besides you lost the credibility you never had with me when you claimed our cooling systems were so over engineered they need a thermostat.
Siva283 is offline
post #23 of 53 Old 04-02-2013, 11:29 AM
Xpress
Fine, see ya. I don't have a single **** in the world to give. I have more important matters than proving someone wrong (once again) about 2.5L power output.
Believe your 30hp theory all you want, it's not true, not in the slightest. NOWHERE does Chrysler claim there to be a 30hp difference between the 2 engines.
Xpress is offline
post #24 of 53 Old 04-02-2013, 11:29 AM
Xpress
Let me asks you this:
Why, without a thermostat, do our engines run colder than they should?
And don't just use your heated opinion, use your brain.
Cooling systems are often intentionally over-engineered to provide MORE than enough ample cooling through a variety of climate changes. A thermostat is required to regulate the cooling temperature within a very small range to keep the engine at a specific operating temperature.
Xpress is offline
post #25 of 53 Old 04-02-2013, 11:30 AM
Siva283
Xpress
This message is hidden because Xpress is on your ignore list.
Siva283 is offline
post #26 of 53 Old 04-02-2013, 11:32 AM
Xpress
And now he is resorting to childish games. Guess I won the argument since he couldn't handle the facts being placed in front of him.
Idiots, idiots everywhere. And now I have 2 of them on my block list.
To the OP:
Don't believe anything that is said without facts to support it. The difference between the MPFI and TBI 2.5L engines is negligible. If the 2.5L MPFI engines had 160hp to put out, then people wouldn't be complaining about their inability to pull uphill, or having difficulty to get to highway speeds, even with 31" tires.
Xpress is offline
post #27 of 53 Old 04-02-2013, 11:58 AM
Michaelgoesrawr
Xpress
Way to go Xpress. You made him mad and now I can't read his post either!
Michaelgoesrawr is offline
post #28 of 53 Old 04-02-2013, 12:34 PM Thread Starter
flea1987
How much mods would need to be made to drop in the 2.4? from what you said it's alot better than the 2.5, and I'll dow my own research before dropping in stuff
flea1987 is offline
post #29 of 53 Old 04-02-2013, 12:37 PM Thread Starter
flea1987
HP difference is minimal between the 2 2.5's
EDIT: Found this article
http://www.jeeparticles.com/reviews/...m#.UVsZf1eJ_IU
flea1987 is offline
post #30 of 53 Old 04-02-2013, 12:45 PM Thread Starter
flea1987
and the 2.4 kills it in hp and torque
http://www.allpar.com/mopar/24.html
flea1987 is offline
