Wrangler here I come! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Wrangler here I come!
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 03-27-2001, 06:15 PM   #1
Keith
Admin
Keith's Avatar
1982 CJ7
Well the CJ was having to many problems and I didn't have the time to address them leaving it undriveable. So I have sold it to someone who has time and will put it back on the road. So now I am in the market for a Wrangler.
I am right now looking at an 1989 Wrangler (4 cyl, 5 spd) It is pretty flawless and asking around $3500.
Could I hear some comments on this setup. I heard the AX-15 is pretty much junk, axles are junk, transfer case is fine, motor is fine. I have no real experience with Wranglers so any insight would be helpful.
Beer Forum - Commercial Beer Discussion Forum
Glock Forum
Keith is offline   Reply With Quote
Unread 03-27-2001, 09:32 PM   #2
Cody_91YJ
Hey Keith, welcome to the club hehe
The AX-15 is fine, I've seen em behind 350s. (wouldn't recommend that though)
But if its a 4-banger, it should have the
AX-5, which isn't quite as good.
But behind a 4cyl, you should have no problems.
The axles are fine, unless you go to 35s and
low gears and lockers. (Even then they are ok if they aren't overly abused, just carry some spare parts)
The Dana 30 is a good axle, and with a shaft upgrade and truss is a capable axle. The Tri-County gear YJ runs a Dana 30 front in the RockCrawling Championships and does very well.
As for the 35C rearend, it's a bit weaker. I'm about to swap mine out for a Ford 8.8" hopefully next month
The X-fer case is good, particularly with an SYE conversion and the new 4:1 ratio kit, and the 4-banger is a good engine if you don't mind the smaller output.
I hope that helps a bit, if you need more help or more specific/detailed info. PM me or visit my website and shoot me an email.
You'll have to send me some pics for my site when you get your jeep
'91 YJ Mangler w/ too many mods...and yet not enough ;)
[url="http://www.Jeeps-Offroad.com"]www.Jeeps-Offroad.com[/url]
Cody_91YJ is offline   Reply With Quote
