Wrangler has poor heat and runs cool - Page 2 - JeepForum.com
post #16 of 51 Old 01-04-2008, 07:14 PM Thread Starter
RednekWrangler
I blocked half the radiator, still no heat and still running cool.
RednekWrangler is offline
post #17 of 51 Old 01-04-2008, 07:17 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Have you tested the actual temp of the fluid in the rad??
Is it possible you have a bad gauge AND a heater core issue????
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #18 of 51 Old 01-04-2008, 07:30 PM
TG Reaper
UP here in the great white north I run a 195 deg. t-stat and a full grill cover this is the only way the guage will come up to the 90 deg.mark (Cdn.model this is 194 F.)
Regards:
TG Reaper is offline
post #19 of 51 Old 01-04-2008, 07:40 PM Thread Starter
RednekWrangler
Upper and lower radiator hoses are cool to the touch. And this problem happened instantly. If you turn the engine off the upper hose starts to get hot and you can turn the key on and see the gauge get hotter. Do you you think it's a possible circulation problem? Water pump or radiator? I would think it would run hot if it was. The temps here are in the single digits wich may keep the engine cool. A week ago I had good heat in the the same cold temps.
post #20 of 51 Old 01-04-2008, 08:27 PM
rustywrangler
Something is plugged OR your waterpump took a crap. Your gonna have to pull everything apart to flush stuff so you may as well pull the pump off and check it out while your at it.
post #21 of 51 Old 01-05-2008, 02:07 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
hummmm, the master jeep god at advance auto told me they came with 180's and that's what i always ran in my 2.5 b/c of what he said....
guess it's time to see what i put in my 4.0 a couple months ago... lol
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #22 of 51 Old 01-05-2008, 06:03 AM
rustywrangler
YOu got one of them too LOL, I thought my AA store was the only one. Mine told me I have a TJ
post #23 of 51 Old 01-05-2008, 09:47 AM
workn4livn
workn4livn's Avatar
If his temp only goes up to 125 then engine is not getting any coolant. I would remove the themostat, start the engine and watch the coolant in the radiator to make sure the water pump is circulating. if coolant is circulating then put a new stat back in and drive it to get it up to temp. The new stat you have may be bad.
workn4livn is offline
post #24 of 51 Old 01-05-2008, 11:33 AM
90yjkrawler
If his engine was not getting any coolant then the engine would over heat. When a water pump goes out the engine over heats not cool down. It is possible that you got a bad stat. I've had that happen before. You said the hoses don't heat up until you shut down. Does the radiator get hot? This is an odd problem unless the radiator is blocked but the engine would then over heat. Does the engine seem to be running alright? Loss of power or anything?
Until They All Come Home!
90yjkrawler is offline
post #25 of 51 Old 01-05-2008, 03:49 PM Thread Starter
RednekWrangler
I have heat! The new thermostat was bad. First time I ever got a bad one. Thanks for the input!
post #26 of 51 Old 01-05-2008, 04:21 PM
rustywrangler
Glad you got that fixed. It is not uncommon to get a bad Tstat.
post #27 of 51 Old 01-05-2008, 05:01 PM
RCHavok797
RCHavok797's Avatar
It just makes sense that is was a bad tstat. If the tstat was stuck open even slightly then coolant would continue to flow threw it not giving the engine a chance to get up to temperature. When you shut the engine off, the temperature would begin to climb since the coolant would no longer be moved via the water pump. I'm glad you solved your problem and that is was a cheap fix.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #28 of 51 Old 01-05-2008, 05:02 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
i'm ecstatic to hear you got it fixed b/c as bad as the problem was annoying you, it was truly ticking me off that your problem had us ALL stumped.
post #29 of 51 Old 01-05-2008, 05:57 PM
rustywrangler
I was pulling my hair out trying to think of what could be causing this.
post #30 of 51 Old 01-05-2008, 10:29 PM
DR8
DR8's Avatar
I have been following this post because I have the same problem! Jeep gauge barley moves... I replaced tstat in summer and it was OK but now that it is colder I have very little heat! Looks like it's time to hit Napa for another tstat! Thanks for the info!!!
DR8 is offline
Poor Heat: what am I missing? richla TJ Wrangler Technical Forum 17 01-06-2010 04:00 PM
97 wrangler blows cool air for heat Mikerp97 TJ Wrangler Technical Forum 0 11-01-2008 09:39 AM
poor heat from heater core marko686 TJ Wrangler Technical Forum 5 09-20-2008 11:19 PM
Poor heat sheamus YJ Wrangler Technical Forum 2 09-08-2008 11:53 AM
Poor Heat In My '97 Tj. Swedejeeper TJ Wrangler Technical Forum 8 12-23-2005 07:49 PM
