Wrangler 4.2 engine temp - JeepForum.com
post #1 of 8 Old 06-12-2013, 05:19 PM Thread Starter
nikondsindent
i have a 89 wrangler 4.2 I6. i wanted to know what the normal operating temp is. my guage seems to only read up about 140-150. this seams really low.???
Would this cause my jeep to run richer because the computer is trying to put more fuel to get the jeep hotter?
nikondsindent is offline
post #2 of 8 Old 06-12-2013, 05:44 PM
roadyrob
1987 YJ Wrangler
you need a new thermostat, should be running around 190.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 8 Old 06-12-2013, 07:13 PM
Rproject
1987 YJ Wrangler
Sounds like your thermostat is stuck open. I went with a 185 when I replaced mine.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #4 of 8 Old 06-12-2013, 07:53 PM Thread Starter
nikondsindent
Would stuck open cause a more rich run less fuel economy since the car thinks its cold?
post #5 of 8 Old 06-12-2013, 08:29 PM
Cashcrazy
1983 CJ7
Mine sits on 160 and smells very rich. I'd like to know this also.
Cashcrazy is offline
post #6 of 8 Old 06-12-2013, 08:47 PM Thread Starter
nikondsindent
Trying to pass smog, my first attempt failed at 8% CO when it should be .59%. >> Fixed carb and vac lines. Then second attempt brought me to a 2.8% >>> I believe the thermostat is stuck open making the jeep too cold telling the computer to burn more fuel to heat it up causing my rich status.
post #7 of 8 Old 06-12-2013, 09:40 PM
packdog
Yes
Yes it can affect fuel economy. If the computer thinks the temperature is low it will add more fuel to the mix. I doubt the difference between 140 and 180 would make a noticeable difference in gas mileage though. However, since it takes longer to warm everything up when the thermostat is stuck open, you would be running in a richer condition for a longer period of time. Hope that makes sense.
That is actually how some if those gadgets that claim to improve fuel economy work - they are just a resistor that gets installed in the temperature sensor circuit (usually intake air temp if the vehicle has one) to feed a false reading to the ECU.
packdog is offline
post #8 of 8 Old 06-13-2013, 06:47 PM
87laredo
1987 YJ Wrangler
X2 I just purchased a new OE thermostat and water pump and the motor now runs at 190 to 200.
87laredo is offline
