Would you buy? - JeepForum.com
post #1 of 9 Old 03-07-2013, 03:12 PM Thread Starter
metalhead
2011 WK
Would you buy?
I found a 1994 YJ for 1200 bucks. The ad said it runs but has a small fuel leak under the hood and a little rust underneath. It is a 4cylinder 5sp. I am looking for a cheap summertime ride/ long term project. Just curious if the fuel leak is a common problem and give me some ideas were to look for it when I do go look at it.
metalhead is offline
post #2 of 9 Old 03-07-2013, 03:55 PM
b_a_mech
Some people's view of a little rust underneath are actually clearance windows in the floor( you can if you cleared that rock/stump without getting out of the jeep). Better check it make sure nothing is push through.
Fuel leak? Oil leak? Air leak? Whatever! Probably needs new o rings on a injector or a line is dry rotted and needs replaced. That stuff is usually simple compared to cutting an replacing floor panels.
Could be a good deal for a starter rig
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline
post #3 of 9 Old 03-07-2013, 03:57 PM
Andywear
post pic then wait for forsure answer
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #4 of 9 Old 03-07-2013, 03:58 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Nope. Round is where it is at.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #5 of 9 Old 03-07-2013, 04:07 PM
roadyrob
1987 YJ Wrangler
TROLL
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #6 of 9 Old 03-07-2013, 04:15 PM
chinuck
As long as the rust is not a major issue i would jump on it.
chinuck is offline
post #7 of 9 Old 03-07-2013, 04:26 PM
MJDriver
MJDriver's Avatar
The fuel injection is fixable - just be safe, wear gloves, and relieve the fuel rail pressure before you take it apart (hint - look for the little black cap on the fuel rail for relieving pressure - cover it with a paper towel to keep it out of your eyes and from dripping).
The rust....everything rusts. Its a matter of degrees and replaceable parts, and jeeps have lots of those available.
Good luck. I dig mine, even when it's yard art and can't move under it's own power. Its so cool getting it back on the road.
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline
post #8 of 9 Old 03-07-2013, 05:37 PM
seattle_yj
Fuel lines aren't so bad. I would rather do that then body rust.
Sounds like a good deal.
seattle_yj is offline
post #9 of 9 Old 03-07-2013, 05:50 PM
pasinbuy
94 and 95 were the best years for the Yj. Due to upgrades. A good find if not rusted.
pasinbuy is offline
