Would these symptoms indicate a bad fuel pump - JeepForum.com
post #1 of 7 Old 08-06-2005, 07:18 PM Thread Starter
gary1
gary1's Avatar
1995 Jeep Wrangler 2.5L 4-cylinder engine. Multiport Fuel Injection.
The jeep started and made it to the end of my driveway and then stalled. There doesn't seem to be any fuel present when checking the valve on the fuel rail. (No, it's not out of gas)
I am assuming the fuel pump is in the gas tank, and with the key turned on, the fuel should shoot out the valve when depressing it.
Is there a fuel pump shut off on the jeep, similar to most cars that can be reset with a button in the trunk.
If it does turn out to be the fuel pump, is it a job a shade tree mechanic could handle in the garage.
gary1 is offline
post #2 of 7 Old 08-06-2005, 07:45 PM
jblockhead
I think you are correct. maybe the fuel pump didn't come on when you first started to go down your driveway, you just used to rest of fuel that was in the rail and lines. A good way to check for the pump working is to hear it energize(sounds like a hum in the tank) when you turn the key on. If not, then check for power to the pump, or you can just use a rubber mallet and hit on the bottom of the tank as someone tries to start it. Jeep doesn't have a shut off switch, sorry on that one. Removing the tank is easy, i don't think you need to raise the it at all.
._______
[l_,[____],
l---L -[]lllllll[]-
()_) ()_)---)_)
92 YJ Red
Bestop Halftop, VDP sound wedges, Body lift
2 inch shackles, 33" Firestone Destination M/T
jblockhead is offline
post #3 of 7 Old 08-06-2005, 07:50 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
That could also be a clogged fuel line or fuel filter. I would check to see that you are getting juice to pump and if you are change the fuel filter next.
To view the NEW
click here!!!
tobias94yj is offline
post #4 of 7 Old 08-06-2005, 08:06 PM
Why J?
Why J?'s Avatar
i'm not sure about a 95 but on my 90 there is a fuel pump test wire in the engine compartment. mine is a red wire on the pass fire wall. It has a black connector on it.next to it ther is a post to connect it to you. if you connect this wire the fuel pump will kick on with the key in the on position but not started. before i knew what mine was i plugged it in and when i turned off my truck it kepped running because the fuel pump would not shut off.
Why J? is offline
post #5 of 7 Old 08-07-2005, 06:55 AM
drew2000
drew2000's Avatar
I don't think there is a rollover switch on our jeeps.
You can test your fuel pressure by hooking up a fuel pressure gauge to the schrader valve on the fuel rail. Should be in the mid 30's IIRC. Also, you can test your fuel pressure regulator while you are there.
Dropping the tank is the only hard part about replacing the fuel pump. I consider dropping the tank to be a royal pain in the a$$, but it seems to come easier to others.
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #6 of 7 Old 08-07-2005, 09:00 AM
TellyDSP
Poland and PPV!!!!
Definatley try your filter first. I went to leave Jersey a couple weeks ago and made it 100 ft from my dads driveway and broke down. THe jeep just died. Started it up, it lasted 2 seconds, and died again. Decided to try the cheap fix first, and sapped the filter. She started and choked for a minute. I cranked her again and she started right up. No problem since. Definately try the cheap fix first.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #7 of 7 Old 08-07-2005, 10:22 AM
paintguy
I concur ^ always start simple.
paintguy is offline
Bad fuel pump symptoms ? chaznad TJ Wrangler Technical Forum 12 05-11-2016 07:24 AM
Fuel Pump Symptoms - Need Help LIGHT-HOUSE YJ Wrangler Technical Forum 38 03-19-2016 02:51 AM
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 05:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
