would these gears be good?? - JeepForum.com
post #1 of 10 Old 11-04-2011, 03:55 PM Thread Starter
happy1426
i was told for my 88 yj with 8" lift on 36"s still has stock gears i believe it came with a 4.0 carb, and the guy i bought it off, swapped in a 4.0 efi so i find it kinda sluggish with the big tires.. I was told to look for a jeep yj with a 4cyl and get the gears our of it,, few questions i have
what years??? front and rear?? does 5spd or auto make a difference probably not.. thansk for your help!
happy1426 is offline
post #2 of 10 Old 11-04-2011, 05:34 PM
tonylax48
4 banger axles wont cut it. 5spds came with 4.10s you would want at least 4.88s with your setup. I would also start looking for a ford 8.8 rear to replace your d35 when it grenades itself with those big tires.
1990 YJ soon to be 4.7L, auto, d30 4.11 w/ spartan locker, ford 8.8 4.11 open, sye, 4in RC 2in BL
tonylax48 is offline
post #3 of 10 Old 11-04-2011, 06:02 PM
I8AHUMR
I just went with 35's and have 4.10s. It's adequate. Nice balance with highway and trail. To each his own but everyone always says 4.56s or lower. Not me. Everyone has there own preference. You can find 4.10s out of a 4 banger pretty easy. I personally think auto vs manual is different. People with manuals always tend to the lower gears.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #4 of 10 Old 11-04-2011, 10:15 PM
redrubi03
I'm running 4.56 and 37s and wouldn't want to run any higher. 4.88 is too steep in my opinion. don't waste you're time looking for 4 banger axles 4.10's won't be enough you'll need to regear anyways
redrubi03 is offline
post #5 of 10 Old 11-04-2011, 10:30 PM
dodger889
Manual trans and autos do make a big difference in what gears to run. Manual when everything is work right does not have any slipping in them ( loss of torque band). Where as an atuo does allow for this slippage and in a basic way gives to the torque band a little easier. So an auto can use a higher gear ratio and still have the torque to power through. With a manual if you where to do the same thing you would burn up the clutch. So with all that said if you have an auto with say 4.10 gears would be like having a manual with 4.58 or 4.88 gears in. This would give you about the same performance in the first 3 gears on the manual trans. Now this is where the auto comes in to its glory is once it is beyond that. The auto would still be able to power up to a speed and be under less rpm than the manual trans. You would still have some slippage in the auto trans until the TC locks up if it has one. But there is less loss energy at that point. Where as the manual trans does not have that loss anywhere.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 10 Old 11-04-2011, 10:34 PM
Hussler
1992 XJ Cherokee
I would not buy used gears to transplant. Either whole axles or new gears. not worth the headache
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #7 of 10 Old 11-04-2011, 10:36 PM
scubamc
I ran 4.56s with 35s and wished I had 4.88s. Now I'm running 5.13s with 37s and love it.
scubamc is offline
post #8 of 10 Old 11-04-2011, 10:50 PM Thread Starter
happy1426
So can someone point me in the right direction for what I need!!! I still want a run it on the hwy but off road too!! It seems now I can't go past 4 th gear or it will pull it self right down!!
post #9 of 10 Old 11-05-2011, 12:37 AM
DigitalPunk
I am running 4.56 with the auto. If I had a manual 4.88s for sure. I am running 35s. My jeep feels as fast if not faster then it was stock and will still cruise at 70 mph.
DigitalPunk is offline
post #10 of 10 Old 11-05-2011, 06:37 AM
I8AHUMR
It's hard to tell you what you need. It's about what you want and your preference. If you a manual I'd say 4.56 or lowrr (numerically higher). If auto 4.10 might be good enough. Just educate yourself and try to make the right decision so you don't have to do it twice. Make sure your decision doesn't include the 35 in the rear. Your upgrade won't be cheap.
I8AHUMR is offline
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Good quality gears? Chilly TJ Wrangler Technical Forum 16 03-21-2010 02:17 PM
US Gears any good? FuzznYJ YJ Wrangler Technical Forum 3 07-01-2009 07:54 PM
are Yukon gears any good jeepy-chan TJ Wrangler Technical Forum 11 04-15-2009 12:14 AM
what are a good set of gears? my04greentj TJ Wrangler Technical Forum 5 03-14-2009 08:32 AM
