Quantcast Would a simple lantern battery power fog lights (not attached to car) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Would a simple lantern battery power fog lights (not attached to car)
Old 03-10-2007, 02:29 PM   #1
JeeperCane
OK, confusing title, but what I mean is I've gotten a lot of great feedback on here about the best way to wire my fog lights. I went out and tried to wire it outside my jeep before I went ahead and drilled the bumper, but I can't seem to get them to work. If I wanted to mess around with things in my living room to make sure everything is set up correctly, could I use just an old lantern battery to power them? Is that enough? I was thinking it might be more convenient until I figured out the right way to set things up (with the relay) before I moved outside. I also think I might not have securely connected the wires to each other, so that could be part of the problem. I just want an easier way to mess with it before putting it in the car.
Thanks
1995 YJ 2.5
31's, BestTop Super Top, Herculined tub, fog lights, TJ rear bumper
Low Output 4 Cylinder Jeep Club Member #68
JeepForum Night Crew #75
JeeperCane is offline   Reply With Quote
Old 03-10-2007, 02:39 PM   #2
kankan
When I was setting everything up on mine I just pulled the battery and used it in the house for testing.
YJ 4.0 HO, SOA with 3.5” BDS Springs, 3/8” Bonz shackles, 33 BFG A/T,
03 Dodge Ram 2500 Heavy Duty 5.7 Hemi, stock so far
Current Projects
Full width Danna 60s
ON THE Back Burner untill the axles are in
Comp Cut Rear
Stretching the rear with XJ Springs
kankan is offline   Reply With Quote
Old 03-10-2007, 02:50 PM   #3
JeeperCane
..........or i could stop being lazy and do that.
1995 YJ 2.5
Old 03-10-2007, 05:42 PM   #4
Brown Dog
Vendor
Brown Dog's Avatar
Lantern battery would not have the amperage. It might work for a minute or two...watch for things (battery and wire) getting real hot from the voltage drop.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Join our FaceBook group
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% MADE IN AMERICA
OFFROAD-REVIEW of Browndog Superkit
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" BFG Mud Terrains
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Old 03-10-2007, 05:47 PM   #5
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
aren't lantern batteries only 6v? if thats the case you could wire two in parallel and do as you described but battery life would be pretty short...
lights are easy to wire up. what sort of problem are you having? a voltmeter or test light would be far easier if you are tryingt o troubleshoot rather than to uninstall, setup in the house, test, then reinstall and hope for no problems....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Old 03-10-2007, 06:59 PM   #6
chim
The batteries probably wouldn't have enough amperage for long (if at all). They'd need to be in series to get two 6-volt batteries to provide a 12-volt output.................chim
chim is offline   Reply With Quote
Glock Forum
