Would a newer tranny work? - JeepForum.com
post #1 of 3 Old 04-01-2010, 11:06 AM Thread Starter
cesarcal1
Ok so I am in the process of looking for a replacement tranny for my Jeep. I have found older and newer trannys along with TC. My question is if it came from a 4cyl and the transfer case comes with it what years will bolt up without having to replace the clutch. Mind you I would be using whatever MC/ slave setup is being used on the replacement tranny. The reason I ask is I found a tranny/ tc combo from a 1988 and also one from a 1994 but am unsure if there would be any problems bolting up. the older one obviously has the internal slave and the newer the external. The person withthe newer one would throw in the MC and clutch so am unsureif anything else would be needed to bolt up.
cesarcal1 is offline
post #2 of 3 Old 04-01-2010, 06:05 PM
willj20
Go with the one from the 94. External slave set up makes it super sweet. As far as clutch disc pressure plate there pretty much the same part number from 88 to 02. Just make sure you get all the parts for the external slave setup. Almost forgot any ax-5 from a Yj 88 up to 02 will fit without any problems. Don't know about T/C though.
1990 Jeep Yj 2.5 Rattler Bone stock.
willj20 is offline
post #3 of 3 Old 04-01-2010, 08:07 PM
Mark05059
as long as the transfercase is bolted to the transmission it will work fine. The differences are in the input shaft and since its all together then it wont matter.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
will a NP231 J TC from a six speed XJ Tranny work for an AX-15 Tranny New2Jeepin TJ Wrangler Technical Forum 3 12-07-2009 05:36 PM
will this tranny work? tmb821 YJ Wrangler Technical Forum 1 10-23-2009 04:56 PM
Newer model auto tranny in older yj 93YJR YJ Wrangler Technical Forum 1 04-21-2008 02:15 PM
Newer TJ leather shift boot work on 2000 TJ? snellav TJ Wrangler Technical Forum 15 11-15-2007 08:09 AM
Frame work on newer TJ Carpie TJ Wrangler Technical Forum 1 03-29-2006 10:35 AM
