would the 1 inch work - JeepForum.com
post #1 of 6 Old 12-16-2001, 08:59 PM Thread Starter
JYRUS
will a 1 inch t-case drop work with a 4 inch lift! and what gears would i probly have in a 4.0 95 sahara?
JYRUS is offline
post #2 of 6 Old 12-16-2001, 09:07 PM
RodeoRob
RodeoRob's Avatar
Yup. my friend YJ is running the RE 4" lift and it uses a tcase drop. She hasn't had any need for an SYE, no highway vibrations or anything.
does your '95 have an auto or manual tranny?
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 6 Old 12-17-2001, 06:21 AM Thread Starter
JYRUS
manual. i was going to do the sye later but trying to save money right now. will revolver shackles help any with flex or will it just mess up the pinion angles with the extra lift they provide?
JYRUS is offline
post #4 of 6 Old 12-17-2001, 01:52 PM
Dan Morera
Dan Morera's Avatar
my girlfriend disagrees with the one inch deal.
YJ Sahara 88, 258 I6, BA/10
2.5" Susp. Lift (Aprox.), 1" Shackles 31x10.5" Cooper
Dan Morera is offline
post #5 of 6 Old 12-18-2001, 07:58 PM
IBjeepN4mud
Sorry to jump in But the 1" TC drop is only to correct your drive shaft angle and to keep most of the sliped end in the TC.
Otherwise a longer drive shaft is needed at full articulation so your shaft wont fall out.
The SYE is for when you loose your drive shaft that you won't loose your fluid and burn up your TC.
Then comes the CV joint drive shaft. Now this baby will keep vibration down to a min.and you can have a high lift without the 1" TC drop. That means more ground clearance.
You don't think 1" makes much difference just wait until your rock crawling.
1st jeep 83 cj8 scrambler
2nd jeep 92 yj wrangler
3rd jeep 88 yj wrangler
4th jeep ??????????? Still looking
IBjeepN4mud is offline
post #6 of 6 Old 12-18-2001, 08:13 PM
IBjeepN4mud
Forgot to mention about your gears.
There should be a data plate on the diff with the gear ratio. My 92 5 spd had 3.07 gears.
Another way is to jack up the jeep and mark the drive shaft and rear diff with tape. Then turn your rear tire 1 revolution while watching the drive shaft and count how many times it turns.
If it turns 3 complete turns and about 3/4 more than it is probly a 3.55
Will a spare tire extender work with 35's on 18 inch wheels jfitlow JK Wrangler Technical Forum 18 11-19-2009 09:22 AM
4 inch springs with 1 inch spacer? will it work? 99TJtommy TJ Wrangler Technical Forum 19 11-17-2009 08:23 PM
1 inch body lift and 32x11.50 will it work? BoostedTJ TJ Wrangler Technical Forum 1 05-04-2009 09:16 PM
Does Mopar 4 door 2 inch lift kit work on a 2 door? enrapture6 JK Wrangler Technical Forum 8 01-31-2009 12:36 PM
If you're on a budget, and need a 4 inch lift FAST..would this work? Tacoma750 TJ Wrangler Technical Forum 21 01-03-2007 10:47 PM
