Worth rebuilding transmission? - JeepForum.com
post #1 of 17 Old 06-19-2013, 12:36 PM Thread Starter
drifts14x
So, I'm looking at buying my first Jeep. My father has a 95 YJ, and I love it, so I decided to look for one of my own.
I found a 1988 YJ, 4.0, 5-Speed, that needs some work, but the price is very workable.
The issue is, the truck has a bad transmission. Apparently, it pops out of gear, and sometimes, won't go back in.
I assume it would have the AX15, and I need to know, how much something like that would cost to entirely rebuild, or replace with something similar.
Is it worth digging into this jeep?
drifts14x is offline
post #2 of 17 Old 06-19-2013, 12:59 PM
Reddy89
It should have the AX15, considering he went through all of that trouble to swap in a 4.0 he would've put a AX15 behind it. (Make sure it is indeed the 4.0 and not the 4.2)
Around here you can find a used AX15 for $300, but you can also consider getting it rebuilt, there are plenty of threads around here for a DIY.
Make sure you go over the frame with a screwdriver.
Reddy89 is offline
post #3 of 17 Old 06-19-2013, 01:11 PM Thread Starter
drifts14x
How would I know the difference between a 4.2 and a 4.0?
Also, why would I want to avoid a 4.2?
Glad I asked. I am definitely going over it with the old screwdriver, but if it's a 4.2 and that's a bad thing, I would like to know why.
post #4 of 17 Old 06-19-2013, 01:14 PM
89yjislanderr
what reddy said. are you certain its not a 4.2? they didnt start the 4.0's till 91 i believe. if it is infact the 4.2, then its got the peugeot transmission in it, which is a piece of **** anyway. if the jeep is a doable price, id get an NV3550 5 speed transmission to put in it. you can get all the adapter pieces you need to put it in on advanceadapters.com.
89yjislanderr is offline
post #5 of 17 Old 06-19-2013, 01:22 PM
89yjislanderr
unless the current owner tells you he put a 4.0L in, its a 4.2L engine. also, the 4.2 is carbureted while the 4.0 is injected. so if it has a carb, its a 4.2. and the 4.2 isnt a bad thing, its just less efficient and less powerful, because its carbureted. i run the 4.2, and have no issues.
post #6 of 17 Old 06-19-2013, 01:35 PM Thread Starter
drifts14x
Good to know.
I was definitely not aware of the engine difference.
I don't really care that much about the power (if it goes highway speed and handles crawling, I'm not going to ask any more out of it).
But the NV3550 conversion is going to factor in heavily.
I was thinking that it would be no big deal to get a factory rebuild of an AX15 (my dad's 95 had to have that done).
Would it be easier to just put an automatic gearbox in it?
Thank you for the advance notice!
post #7 of 17 Old 06-19-2013, 01:37 PM
UZI4U
The AX-15 will have the drain/fill plugs on the driver's side. The frog tranny has them on the right. If it's a frog tranny, you will need to swap it out with an AX-15, unless you want to replace it again.
MCLMM
UZI4U is offline
post #8 of 17 Old 06-19-2013, 01:46 PM
89yjislanderr
I wouldn't get an auto tranny. Takes a lot of the fun put of jeeping in my opinion. Either the ax 15 or nv3550 transmissions will do you good. If that's the only major issue with the jeep, I'd definitely go for it
post #9 of 17 Old 06-19-2013, 02:55 PM Thread Starter
drifts14x
Well, this is no spring chicken. It has no A/C, will need some light body work and a paint spray, but overall, it could be a lot worse. I'd like to say I saved one, but now I'm going to have to see if I can get him to be very flexible on the price.
post #10 of 17 Old 06-19-2013, 03:41 PM
89yjislanderr
Yeah, that's pretty much the same story with my 89. No ac and some dents and paint blemishes.
post #11 of 17 Old 06-19-2013, 04:35 PM
stratostix
Plenty of used good running AX15's out there. I got my most recent one from a cherokee with 88k miles on it for $300. Sold my original ax15 with 193k miles on it for $200. Quick swap and ur in business. Cheapest/best way to go imo.
1994 YJ
1965 Mustang Coupe Hi-po
2003 BMW 325i
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
Jeep Build thread:
stratostix is offline
post #12 of 17 Old 06-19-2013, 05:33 PM
Reddy89
You need to decide whether you want a carbureted (4.2) or fuel injected (4.0) engine.
Post up some pictures if you can!
Reddy89 is offline
post #13 of 17 Old 06-19-2013, 05:49 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
For some reason I thought my ax-15 had the plugs on the passenger side.
Edit: Max seems to think so too.
http://www.jeepforum.com/forum/f12/b...change-865520/
Anticanman is offline
post #14 of 17 Old 06-20-2013, 07:30 AM
UZI4U
Excuse my alcohol induced dyslexia.
MCLMM
UZI4U is offline
post #15 of 17 Old 06-20-2013, 09:43 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Must be an early drinker. No judgement here.
