Is it worth it? - JeepForum.com
post #1 of 6 Old 08-05-2006, 03:21 PM Thread Starter
Kuasimodem
Kuasimodem's Avatar
Is it worth it?
I've been looking at this 89 YJ sitting at a local repair shop for sale while driving by every day going to work. Today curiousity got the best of me and I had to stop and take a closer look.
The side I have been seeing, looks pretty good
Duals???
Cooooooooooooooool! Yes folks, that's a TPI 327 V8 under the hood
The tires are 33x12.50/15 BFG AT's with good tread but a little problem, they're getting pretty weather checked.
Now the bad news:
Stock engine was 2.5L and the stock 5-speed and NP-231 are in place, no SYE. It also has the stock D35 rear and D30 front axles. He's selling it because he doesn't want his teenage son to tear it up
Asking price is $10,000.
Is it worth the 10K? How much would it take to put some real axles under it? Will the stock transmission and TC hold up to wheeling?
BTW - The engine has been very cleanly installed, nothing looks cobbled together except maybe a little cleanup of a sensor wiring on the driverside head.
White Jeep Club Member #1992
Original Rust Jeep Club Member #5!
Old Guy Jeep Club Member #1992
"The most terrifying words in the English language are: I'm from the government and I'm here to help." - Ronald Reagan
Kuasimodem is offline
post #2 of 6 Old 08-05-2006, 03:27 PM
christeve jeep
Most likely the trans and rear end won't be good for any heavy wheeling. Look into a 8.8 rear and an AX15 trans. Both are ezey finds in a junk yard. Check out this site: http://car-part.com/ . The trans will come from a late 89 and up YJ and the 8.8 from a ford explorer 97- 2000 +/-. Good luck.
89 YJ Islander, 4.2, MC2100, Nuttered, AX15, 4" lift, 8.8 (next)
christeve jeep is offline
post #3 of 6 Old 08-05-2006, 03:28 PM
yesterdaylight
def not worth the 10k. maybe 7 or 8 around here.
Green Jeep Club Member #172
Low Output 4 Cylinder Jeep Club Member # 23
Green 1995 4 Banger
If only my pocket was as green as my Jeep :D
yesterdaylight is offline
post #4 of 6 Old 08-05-2006, 03:59 PM Thread Starter
Kuasimodem
Kuasimodem's Avatar
Yeah, I thought it was a bit high too, considering that I can get something like this for $5K around here.
post #5 of 6 Old 08-05-2006, 05:44 PM
yesterdaylight
thats a great deal, nice tire tread left, et. i'd go for it, except its a renegade.
Green 1995 4 Banger
post #6 of 6 Old 08-05-2006, 06:51 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
just get an sm465 4 speed tranny remanufactured unit ($500) and an 8.8... new tires and bam!
i'd offer $7k or so... considering you would dump another $1200 into it once you got it not including tires.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
how much is this worth?? oompaloompasc3 YJ Wrangler Technical Forum 0 10-05-2008 02:50 PM
What is this YJ worth??????? johnrezz YJ Wrangler Technical Forum 3 09-28-2008 07:53 PM
Worth a try rob1525 TJ Wrangler Technical Forum 1 09-08-2008 06:04 AM
Is It Worth It? dirtboss TJ Wrangler Technical Forum 4 05-09-2005 09:27 PM
How much is a 90 YJ worth? 87warrior YJ Wrangler Technical Forum 14 04-04-2005 06:29 PM
