Is it worth it ? - JeepForum.com
post #1 of 5 Old 05-29-2013, 06:14 PM Thread Starter
wayno32m
wayno32m's Avatar
Is it worth it ?
After checking all of my steering components I found that the U-joints on my steering column are shot , My question is it worth the extra $100 for the Borgeson HD column,I do have a 1"body lift and am considering moving my steering box forward 1" with the Parts Mike bracket because of binding.
wayno32m is offline
post #2 of 5 Old 05-30-2013, 04:18 AM Thread Starter
wayno32m
wayno32m's Avatar
Anyone ?????
wayno32m is offline
post #3 of 5 Old 05-30-2013, 06:47 AM
Rproject
1987 YJ Wrangler
Give it time. It's only been a couple hours since your original post. While I'm not an expert on steering columns, from what I'm seeing in your build, I'd want a tougher than stock steering shaft. JMHO.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #4 of 5 Old 05-30-2013, 07:48 AM
acat
I eventually need to replace mine. From the little research I've done in the past it doesn't sound like the HD one would be necessary to me. Not with 35s and power steering anyway.
acat is offline
post #5 of 5 Old 05-30-2013, 08:37 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
A stock replacement should do fine. I believe Fernando did a writeup of sorts on the subject. Maybe it was just a bearing replacement.
Luck Favours The Prepared
Anticanman is offline
