Is this worth it? - JeepForum.com
post #1 of 7 Old 09-01-2011, 08:43 PM Thread Starter
Bad92yj
Is this worth it?
Deleted sorry!
Bad92yj is offline
post #2 of 7 Old 09-01-2011, 09:34 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
It is kinda high. The locker in the front is useless without the compressor. And if the locker in the rear is in the d35 then you could run into problems.
I'd find out what axle is in the rear if a 35 try to talk him down more because it is a liability and there is no compressor in the front. Ask about sye and cv shaft too.
Michaelgoesrawr is offline
post #3 of 7 Old 09-01-2011, 09:38 PM
MiNiSaBa
I am almost sure that has a 35 behind, but I could be wrong. 6000 is making him wealthy in my opinion. You could buy a yj between 3-4000 and put 3000 more into it and have a better jeep than that. The way you want it.
MiNiSaBa is offline
post #4 of 7 Old 09-01-2011, 09:43 PM Thread Starter
Bad92yj
Sounds good thanks!
Bad92yj is offline
post #5 of 7 Old 09-01-2011, 09:44 PM
timatoe
timatoe's Avatar
It's not super high but I've seen some pretty decently built TJ's in the 7k range. Maybe get him to drop another $500 off it.
timatoe is offline
post #6 of 7 Old 09-01-2011, 09:46 PM
jclauson
he doesnt say which motor?
seems high. really high. when i see a 7k YJ on craigslist i expect alot of the expensive upgrades to be done, like axles, gears, etc.
1990 YJ w/ lots of home made sh*t
check it out
http://www.jeepforum.com/forum/f22/hysterias-90-yj-build-1190617/
jclauson is offline
post #7 of 7 Old 09-01-2011, 09:50 PM
MiNiSaBa
Thats true, for that kind of money you can get a tj and maybe get lucky with a rear 44 on it. Its not that much off of 6000. Just a thought, although I love the roughness of my YJ.
MiNiSaBa is offline
Worth it? xj9635 Wrangler General Discussion 6 07-21-2009 07:47 PM
What's it worth? gotdirt TJ Wrangler Technical Forum 7 05-18-2006 10:16 PM
What would you think it is worth? A4x4Junky YJ Wrangler Technical Forum 8 05-16-2006 05:07 PM
what's it worth.. slick2570 TJ Wrangler Technical Forum 13 05-10-2006 07:53 PM
Is it worth it to do this? micfly83 YJ Wrangler Technical Forum 7 05-04-2006 08:33 AM
