wont turn over - JeepForum.com
post #1 of 6 Old 04-24-2013, 01:50 PM Thread Starter
bobblinking
wont turn over
i have a 1995 jeep wrangler the ignition switck burnt out and i but a new one in and now the jeep wont turn over please help
bobblinking is offline
post #2 of 6 Old 04-24-2013, 09:33 PM
Fenix85182
Fenix85182's Avatar
How do you know the ignition switch was burned out? Do you get dash lights when you roll the key into the 'on' position? When trying to start, does the starter crank? Does it just click then cut out? Need more info--if your key does roll into the 'on' position and the dash lights come on, pull your engine codes and see if anything shows up.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #3 of 6 Old 04-25-2013, 12:34 AM Thread Starter
bobblinking
no i got noting put a ne switch and now i have lights but tha starter wont engage. I replaced th burnt out starter fuse and the starter relay i think it the starter now.
post #4 of 6 Old 04-26-2013, 10:00 AM
Que89YJ
In your PDC fuse box under the hood you have a starter relay. With the Jeep out of gear remove the relay and use a short piece of wire and jumper pimns 30 to 87 in the relay socket. It should turn over the starter. Post back what it does.
Que89YJ is offline
post #5 of 6 Old 05-07-2013, 04:53 PM Thread Starter
bobblinking
i bypassed that relay so it is bad and the jeep started and ran for about min then it died and i saw smoke from the dash and i checked the 40amp fuse under the hood and it was blown again
post #6 of 6 Old 05-13-2013, 02:42 PM
Que89YJ
any luck?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
