-   -   Won't start till she's floored (http://www.jeepforum.com/forum/f12/wont-start-till-shes-floored-1468114/)
NMYJ 01-23-2013 08:13 PM
Hello all-
Just got my second YJ 93 - 242 5sp with 200+
Every morning she has been starting right up. But more and more I'm finding that she won't turn over till the gas pedal is floored. Then it smells like she's flooded.
I'm thinking a nice tune up (wich was on the way any way) plugs, wires, cap, roter, maybe crankshaft positioning sensor.
But just wondering if anyone has experienced the same or if it maybe anything else?
Thanks! :cheers2:
Jeepsr4me 01-23-2013 11:45 PM
Sounds like leaking injectors flooding it. Thats where I would start looking..
bogleparsons 01-24-2013 06:56 AM
Mine does the same thing. It's the injector i believe.
Que89YJ 01-24-2013 07:20 AM
Check your fault codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Does it make any difference if it has been running for a while and has warmed up and you go to restart or is cold/warm start the same dificult time starting?
Basic maintenance; tune up plugs, wires, cap, rotor, fuel filter. Clean the IAC and throttlebody:
http://www.jeepforum.com/forum/f12/q...-body-1262267/
Possible real issues would be fuel: Run a fuel pressure test by hooking a guage to the fuel rail:
ignition on 31psi, running with vacuum line to the pressure regulator disconnected 39, turn the ignition off and it should maintain pressure above 20 psi for 20 minutes.
Bad temp sensor (Near tstat housing) can be checked with a meter.
Bad TPS can also be checked with a meter.
Jeepsr4me 01-24-2013 08:20 AM
My reasoning for saying leaking injectors, is when there is too much fuel in the cylinders, you will need to clear some of it out. Pressing the gas petal does not make fuel squirt in like a carb, but allows more air to get in and clear the fuel to air ratio back to a point it will fire. Pulling fuel rail and cleaning each injector is easy enough. There is a good write up on here on how to do it.
Que89YJ 01-24-2013 08:35 AM
The fuel pressure test should show an injector issue. Hey Jeepsr4me, I dont have that link. Can you post it? I would like to add it to my collection of bookmarks.
Jeepsr4me 01-24-2013 08:38 AM
Sorry, I dont have the link, would just have to search for it. But I have seen it referenced a few times.
NMYJ 01-24-2013 09:19 AM
Thanks for advice everyone! This gives me some stuff to do this weekend! :D
The time now is 11:21 PM.
