wont start need help - JeepForum.com
post #1 of 4 Old 01-21-2010, 12:08 PM Thread Starter
w212warren
hi i just put in a new 4.2 in my 89, i got spark and fuel but it wont fire up. it gets so much fuel it leaks out the header and gas starts on fire under the jeep. what could be my problem?
w212warren is offline
post #2 of 4 Old 01-21-2010, 12:47 PM
Mark05059
timing issue sounds like your 180 out by all the fuel thats dumping out of it
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 4 Old 01-21-2010, 12:51 PM
YJBlues
YJBlues's Avatar
that would be my first guess, distributor dropped in 180 degrees out. bring it back to TDC and check the distributor, if its pointed at #1 plug, pull the distributor and turn the motor over again to TDC and put it back in, if it's not pointed at #1 plug, pull distributor and point it at #1.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #4 of 4 Old 01-21-2010, 06:57 PM Thread Starter
w212warren
well i got it running, it was a easy fix i had the #1 plug wire on the distrubtor on the #5 wire spot. thanks for the help thow guys!!
2.5 cranks but wont start...Cold start SnowdogMarc YJ Wrangler Technical Forum 4 08-04-2009 08:16 PM
Starts, Idles, Dies, Wont Start, Wont Start, Pump Pedal, Starts... REPEAT inniett YJ Wrangler Technical Forum 2 04-08-2009 05:13 PM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 09:28 AM
Wont Start... danielp YJ Wrangler Technical Forum 4 04-15-2008 05:30 PM
yj wont start!!!!! CrSublime YJ Wrangler Technical Forum 12 10-02-2006 10:09 PM
