Won't start after warm up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Won't start after warm up
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-25-2007, 08:28 PM   #1
starkey
Got a 90' yj and after a few miles then shut engine off for few minutes it won't start. Any ideas? I thought I had fixed the problem but didn't test it long enough.
starkey is offline   Reply With Quote Quick reply to this message
Unread 03-25-2007, 11:21 PM   #2
pyro9862
Perhaps the motor is flooding?
My Jeep does the same thing. When cold it will start up fine, shut it off and it starts back up fine, shut it off and let it sit five minutes and it won't. Trick in mine is to hold the pedal down to the floor. Probably not good for it but until I figure out the problem (I think I need a fuel pressure reg with my MC2100) it's going to have to do.
pyro9862 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2007, 12:50 AM   #3
sofixj
i had a similiar problem in my 89 it was an ASD relay auto shutdown relay
,=====o00o
//___l__,\____\,___
l_--- \___l---[]lllllll[] _
_(o)_)___(o)_)--o-)_) only in a JEEP
sofixj is offline   Reply With Quote Quick reply to this message
Unread 03-26-2007, 07:22 AM   #4
paintguy
could be the coil is going bad -- usually when a coil is crapping the bed, it runs and starts when it is cold and once the coil heats-up it shuts down and you have to wait for it to cool-off before it will refire. Also, the ignition module (under the coolant overflow bottle) can cause it to not start. Keep us posted
Pray For World Peace and Love -- This is all the World Needs, and ever needed -- Everything else will follow...
paintguy is offline   Reply With Quote Quick reply to this message
Unread 03-26-2007, 08:00 AM   #5
the dit
could be vapor lock. Try adding some sort of heat sink to the metal fuel line, like a bunch of aluminum foil.
89 Yj Sahara, 4.2L, 31X10.5 MT's, Weber carb, nuttered, Mustang Seats, 6" Xenon flares
2004 Dodge Ram 1500 4x4 Hemi
83 Mustang vert
the dit is offline   Reply With Quote Quick reply to this message
Unread 03-28-2007, 12:32 AM   #6
starkey
I took it to the jeep dealership in Glendale AZ to have it tested and they say the fuel pressure regulator is leaking. I thought I heard a little hissing when I shut the truck off. I had replaced that about six months ago, they said don't buy the Checker Auto parts. Now I'm waiting on a regulator to come in, it will take five days to get. $109.99.
Unread 03-28-2007, 08:30 AM   #7
paintguy
that must mean you have a 4 banger with the tbi -- in the mean time while waiting for your fpr to arrive, if you want to start her and it doesn't want to start, turn the key 'on, 'off', 'on', 'off', 'on' and then try to fire her -- this will send more fuel and may help it start until you fix it. Keep us posted on your progress.
Unread 03-28-2007, 08:33 AM   #8
paintguy
(I used to live in Peoria -- Peoria and 77th Ave).
Unread 03-28-2007, 08:34 AM   #9
ramburger
whaen its warmed up and wont start, just put the skinny pedal to the floor until it turns over.
ramburger is offline   Reply With Quote Quick reply to this message
