wont start - JeepForum.com
post #1 of 17 Old 03-24-2012, 10:07 PM Thread Starter
godzilla89
wont start
I have a 89 YJ with a 93 Grand Cherokee 4.0 inline 6. It was running perfect the other day, now it wont start, the battery is brand new, the alternator is good. But there is no power getting pasted the starter solenoid on the firewall. I can not find the engine fuse box and I have looked everywhere in the jeep (not many places to hide it). This is my last effort before I take it to a shop and have them fix it. I'm open to any ideas
godzilla89 is offline
post #2 of 17 Old 03-25-2012, 12:40 AM
mangoman123
Put the original motor back in it lmao. The 4.2l is alright
mangoman123 is offline
post #3 of 17 Old 03-25-2012, 06:02 AM
brentd711
From your profile it looks like you put a '93 motor in it. Did you just use the '93 block and keep the '89 wiring?
I think they had fusible links in the engine bay wiring in both the early and later models.
brentd711 is offline
post #4 of 17 Old 03-25-2012, 06:38 AM
kdub2886
Neutral safety switch ?
kdub2886 is offline
post #5 of 17 Old 03-25-2012, 08:25 AM
Mark05059
not with a manual trans.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 17 Old 03-25-2012, 09:20 AM
inlinerubi
I did a similar thing to my yj but I put a 327 small block in it
inlinerubi is offline
post #7 of 17 Old 03-25-2012, 08:36 PM Thread Starter
godzilla89
i bought it this way, if I had down an engine swap it would have a V8 in it now.
post #8 of 17 Old 03-25-2012, 09:45 PM
mangoman123
That's the whole problem lmao. No, check your flux capasitor under your driver side fuse panel. If that's not it make sure your radiator belt is tight but not too tight. May just need some muffler bearings
post #9 of 17 Old 03-26-2012, 07:44 AM
Que89YJ
It came stock with fuseable links so there is no fusebox under the hood. They look like wires and there are 5 or 6 under the hood if you have the stock wiring. You will see them coming off the starter relay on the firewall. Check the fuses in the fuse box at the drivers feet too. There is an ignition fuse there.
Que89YJ is offline
post #10 of 17 Old 03-26-2012, 09:25 AM Thread Starter
godzilla89
is there gonna be fuseable links even with the engine swap? All the fuses in the fusebox there are good.
post #11 of 17 Old 03-26-2012, 09:31 AM
Que89YJ
The engine might have been swapped but they kept the original setup. If it has a carburator then the sytem was left original with just swapping the block.
Que89YJ is offline
post #12 of 17 Old 03-26-2012, 09:53 AM
brentd711
I thought a saw fusible links in my '93 YJ engine harness, was I seeing things?
post #13 of 17 Old 03-26-2012, 11:20 AM
Que89YJ
You are seeing things. Fuseable links went away with the PDC in 91. Fuseable links were replaced with fuses.
Que89YJ is offline
post #14 of 17 Old 03-26-2012, 01:35 PM Thread Starter
godzilla89
its a 93 grand cherokee engine so why does it have fuseable links if its a 93?
post #15 of 17 Old 03-26-2012, 01:45 PM
jaycal3
I'm coming into this a bit late, but are you getting spark? Have you checked the ignition module?
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
electrical issue , help please , wont start
Help Jeep wont start turns over but wont start 1990blackyj YJ Wrangler Technical Forum 17 01-13-2012 03:33 PM
jeep wont stay running, now wont start 89General YJ Wrangler Technical Forum 5 02-11-2011 05:57 AM
Jump start = Volt Meter spikes while driving then wont start AWILD TJ Wrangler Technical Forum 5 02-21-2010 05:37 PM
Starts, Idles, Dies, Wont Start, Wont Start, Pump Pedal, Starts... REPEAT inniett YJ Wrangler Technical Forum 2 04-08-2009 04:13 PM
