Wont start - JeepForum.com
post #1 of 17 Old 08-15-2011, 09:55 PM Thread Starter
Tikiman357
Wont start
Just fixed the exhaust bolt and manifold, replaced the fuel injectors but now it won't start sounds like it's gonna start but it won't. Would having the vacuum lines hooked up wrong be the problem? I'm kinda stumped? The battery seems a little low but I'm so frustrated!!!! Can anyone help??
Tikiman357 is offline
post #2 of 17 Old 08-16-2011, 12:07 AM
Yjmudding
When you turn the key on and the electronics turn on does the check engine light and gear shift light come on?
Yjmudding is offline
post #3 of 17 Old 08-16-2011, 12:09 AM
MJMPC
Fill out your jeep info we dont know what we are working on.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 17 Old 08-16-2011, 12:16 AM Thread Starter
Tikiman357
It is a 91 2.5, and I know the check engine light does go on
post #5 of 17 Old 08-16-2011, 12:18 AM
Yjmudding
Does it have good fuel pressure?
post #6 of 17 Old 08-16-2011, 12:42 AM Thread Starter
Tikiman357
yea it seemed to flood when cranked over twice, it seemed like it wanted to start when pumped gas three times at half pedal.
post #7 of 17 Old 08-16-2011, 12:51 AM
Yjmudding
Does it almost sputter on when it turns over?
post #8 of 17 Old 08-16-2011, 04:24 AM Thread Starter
Tikiman357
Yea I guess you could say that
post #9 of 17 Old 08-16-2011, 07:13 AM
MJMPC
Have you checked fot codes?
http://www.jeepforum.com/wiki/index....k_Engine_Codes
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #10 of 17 Old 08-16-2011, 08:06 AM
Que89YJ
Hooking up the vacuum lines wrong will definetly cause it not to start. Check the codes and double check the connections. Look at the crank sensor connector at the rear of the engine on the bell housing. Check for codes. Clear them by disconnecting the battery for a long 10 count and recheck after trying to start it.
Que89YJ is online now
post #11 of 17 Old 08-16-2011, 10:16 AM Thread Starter
Tikiman357
I will check later on today to see if there are any codes. I work nights so it's bedtime!!
post #12 of 17 Old 08-16-2011, 07:12 PM Thread Starter
Tikiman357
There are no codes same thing though
post #13 of 17 Old 08-16-2011, 10:15 PM Thread Starter
Tikiman357
The check engine light and shift light does come on
post #14 of 17 Old 08-16-2011, 10:27 PM
Yjmudding
Check all the vacuum lines?
post #15 of 17 Old 08-17-2011, 01:56 AM Thread Starter
Tikiman357
Does anyone have a good picture of where the vacuum lines go, or a diagram. For a Fuel injected 2.5l
