wont restart after reaches temp - Page 2 - JeepForum.com
post #16 of 16 Old 04-12-2010, 07:36 PM
idaholtby
Originally Posted by xboardr311 View Post
just disconnected the cts started up but ran real rough. so im thinking its not that. i think im going in the complete wrong direction. now im thinking fuel problem. when i start it up it misses and the more fuel i give it the worse it gets. its progressively getting worse. i took it out at about 12 this afternoon and seemed fine ran like it normally does. now i have no clue
With these symptoms, you need to know what your fuel pressure is at the fuel rail in order to properly diagnose/rule out this. With a fuel pressure gauge attached to the schraeder valve on the fuel rail,.. at idle you should have 31psi. Then when you disconnect the vacuum line from the fuel pressure regulator (at the front end of the fuel rail), you should have 38 to 41 psi. Test this and report back. Most auto part stores have fuel pressure testers for sale or may even perform this test for free.
idaholtby is offline
Starts but wont restart untill completely cool jonlb YJ Wrangler Technical Forum 16 03-26-2012 11:02 AM
died and wont restart hunterboy2121 TJ Wrangler Technical Forum 4 02-10-2010 07:59 PM
Help... 94 2.5 stalled wont restart airdevil85 YJ Wrangler Technical Forum 1 02-10-2010 05:04 AM
Jeep stalled and wont restart!? JeSimmers YJ Wrangler Technical Forum 1 03-31-2009 08:56 AM
Restart CD from track 1 on restart? liquids JK Wrangler Technical Forum 9 05-07-2008 05:28 PM
