won't go into gear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > won't go into gear
Crawler Conceptz at JeepHut.comTime To Save On Yukon Lockers!Jeep Wrangler Bushwacker Flat Fender Flare Sale at Baselin
Unread 11-14-2010, 07:55 PM   #1
JMAC90YJ
JMAC90YJ's Avatar
won't go into gear
I am ashamed to say, I haven't driven my YJ for about 2 weeks .
Today I started it and while trying to put it into reverse all it did was grind, I could put it reverse and start it and back up ok, and then trying to put it into first gear it would not go.
Does anyone have a clue what my problem may be.
This past spring I had a used ax5 installed and last year had new clutch installed.
After having the tranny installed this spring I didn't have a lot of clutch pedel and now it goes to the floor.
Please help!
JMAC90YJ is offline   Reply With Quote Quick reply to this message
Unread 11-14-2010, 08:02 PM   #2
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Have you checked the fluid in the clutch master cylinder yet?
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 11-14-2010, 08:46 PM   #3
JMAC90YJ
JMAC90YJ's Avatar
No,
It started to rain pretty hard and I planned on checking it tomorrow.
Unread 11-15-2010, 08:03 PM   #4
SnowdogMarc
I'm going to say it's either the slave or air in the system from the swap. I'm pretty sure you can bleed it without removing anything but I swapped over to the external slave when I did mine last year.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote Quick reply to this message
Unread 11-16-2010, 09:55 AM   #5
JMAC90YJ
JMAC90YJ's Avatar
It ran fine since spring and I wasn't to happy with the clutch pedel but since this was not my DD i didn't worry to much about it. I will search but it there an easy way to bleed w/o disassembly?
Unread 11-16-2010, 11:01 AM   #6
swatgig17
1987 YJ Wrangler
In the mean time, you can pump it a few times before you put it in gear. I drove mine like that for two years.
swatgig17 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2010, 11:04 AM   #7
grandboost98
id check the fluid. i have to top mine off every couple weeks or else i cant shift either
04 Grand Cherokee Overland
72 Chevy Nova-in progress
http://tiny.cc/BRASSBALLSOFFROAD
grandboost98 is offline   Reply With Quote Quick reply to this message
Unread 12-12-2010, 09:28 AM   #8
JMAC90YJ
JMAC90YJ's Avatar
Back to this question,
I filled up master cylinder, Jeep goes into gear, shifts ok from 1-2-3-4, but down shifting it is hard to get into the gears.
stopping and trying to put into reverse it still grinds. I have to shut it off and put it into reverse and then start it up.
Please Help!
Unread 12-12-2010, 12:51 PM   #9
MJMPC
Did you bleed the system after you filled it up?
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 12-12-2010, 01:36 PM   #10
JMAC90YJ
JMAC90YJ's Avatar
No,
I did not. I took the advice from above and it wasn't mentioned to bleed the system.
I will look for a link on how to do it.
Can it be done by one person?
Unread 12-12-2010, 02:33 PM   #11
SnowdogMarc
Internal slave...no
External slave..yes but it's not easy.
Best to have a second person to operate the pedal.
l_______
/l ,[_____],
l---L -[]lllllll[]-
Unread 12-12-2010, 05:07 PM   #12
Xpress
Yes, it's a 2 person job with the internal slave cylinder
On my 89, it's underneath the right side of the jeep (looking forward), and it's this guy sticking out of the back of the bell housing:
My bleeder valve is right above my header, just in front of the skid plate.
Be sure to get a rag in there, that fluid screams out of there!!!!! (don't ask how I know )
Xpress is offline   Reply With Quote Quick reply to this message
Unread 12-17-2010, 06:35 PM   #13
JMAC90YJ
JMAC90YJ's Avatar
Update, had the Clutch blead by my local mechanic, He said he blead the clutch and everything seems fine, he thinks my problem is that I do not drive my jeep enough this time of the year and since the tranny has 90 weight oil in it my problem getting it into reverse is because since I do not drive it enough it doesn't get the oil up to a workable viscosity. What do you guys think? Does this make sense?
Unread 12-17-2010, 07:06 PM   #14
Mark05059
I think he is probably right. Drain the 90 weight oil and refill it with 10w30 motor oil. You will be alot happier
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2011, 10:26 AM   #15
JMAC90YJ
JMAC90YJ's Avatar
Jeep has set all winter, I took it for a ride on Sunday and everything seemed fine, shifted great all 5 forward gears and reverse, today I desided to take it to work.
5th gear ground a tiny bit and when I got to work and tried to put it in reverse it started to grind?
I can shut it off and get it into reverse again.
Any thoughts??
