Wont go into gear - JeepForum.com
post #1 of 4 Old 04-27-2010, 09:01 AM Thread Starter
prich464
Wont go into gear
Im new to the Jeep family. I just got my first wrangler. its a 95 YJ. for some reason in the morning it sounds like the starter is spinning and not catching. the other thing is sometimes it wont go into gear. 1st or reverse. where should i start.
prich464 is offline
post #2 of 4 Old 04-27-2010, 09:13 AM Thread Starter
prich464
i wish that i could give you more information about my jeep but like i said i really dont know much. i am learning as i am going. its a 1995 4 cylinder with a manual 5 speed. and thats pretty much all i know. not much has been done to this jeep. its like im starting from scratch.
prich464 is offline
post #3 of 4 Old 04-27-2010, 09:24 AM
shagsjeep
Starter sounds like the bendicts is not throwing out like it should. You could try lightly tapping it with a hammer to see if something is sticking it in. Best bet would be to just replace it. As far as the shifting issue, like you, I'm new to the jeeps and mine does the same thing but with 4th gear mainly. Sometimes it just doesn't want to shift into any gear at all. I dunno much about them so I plan on replacing it, the flywheel, and the clutch.
1989 Jeep wrangler YJ. 4.2L 258 in-line6, front dana 30 rear dana 35?? NP231 nothing fancy yet.
shagsjeep is offline
post #4 of 4 Old 04-27-2010, 09:37 AM
pasinbuy
For the shifting check your master. If the master or slave is leaking it will be wet on the inside of the firewall behind the clutch pedal and down. Look under the carpet for wetness also.. for the master, and under the slave for the slave leaking. Check your master fluid level first.
The other side of hard shifting is fluid. It does not take much to get water in the tranny, look for a whitish color. Also the fluid may be old, I would replace the fluid first.
pasinbuy is offline
wont go into 5th gear!!! yjwrangler YJ Wrangler Technical Forum 16 12-08-2009 01:50 PM
wont go into 2nd gear DOWE TJ Wrangler Technical Forum 7 02-19-2009 02:29 PM
Wont go into gear need help!! Toady TJ Wrangler Technical Forum 4 12-23-2008 09:37 AM
Wont Go into Gear fogertyb TJ Wrangler Technical Forum 3 07-21-2008 12:29 PM
Wont go into gear Nukeproof YJ Wrangler Technical Forum 9 01-29-2003 02:01 PM
