Wont get out of 4low - JeepForum.com
post #1 of 2 Old 01-21-2010, 11:26 PM Thread Starter
ryans93
To start off it has snowed about 3 and a half feet. I was driving some people home on a road that was not plowed very well. The jeep was handling it just fine until I had to turn around. When I went against the tire tracks already in the road I got stuck, so logically I put it in 4low. I got unstuck no problem. But when I went to take it out of low, the knob just moved freely and it would not get out of 4low. I managed to drive home, at a nice 10mph down one of the busiest streets in town. What does this mean when it will not 4low? It drives just fine, I did not hear anything break. Someone told me it might be ice in the shifter, but I think it might be a broken linkage. Has this happened to anyone else?
ryans93 is offline
post #2 of 2 Old 01-21-2010, 11:31 PM
Apollo12227
You busted your linkage it sounds like... Because the stick moves freely... Crawl under and have a look, it's very common for the linkage rod to pop out of the little rubber bushing that holds the rod into the shift tab. You will have to look to know for sure, have a friend move the shifter around while you are under there so u can see what it is doing.
And it's good u didn't hear anything lol linkage breaks quietly but t-cases can break very loudly (thrown bearing, skipping chain, broken shift fork, case busted in half, rear yoke broke, etc... All of which can be very loud to say the least haha)
Apollo12227 is offline
06 jeep wrangler tj ...4low wont engage? mrtJEEP87 TJ Wrangler Technical Forum 5 07-05-2009 02:22 PM
4hi vs. 4low in mud mpgrunt2002 YJ Wrangler Technical Forum 15 02-20-2009 09:16 AM
SYE in 4Low method84 TJ Wrangler Technical Forum 2 04-16-2006 01:29 PM
4hi 4low Joeys97TJ TJ Wrangler Technical Forum 20 05-02-2005 12:07 PM
installed 1"BL..Wont stay in 4low! 98Sahara TJ Wrangler Technical Forum 11 11-24-2004 01:28 PM
